May 22, 2013, 07:48:26 PM *
Author Topic: Spray foam insulation?  (Read 976 times)
zukmancdr
« on: December 25, 2012, 08:20:19 PM »
For the ones that used spray foam, what brand and how much did you use?
« Reply #1 on: December 25, 2012, 09:33:56 PM »
You can use the self spray system. But to do it right you should spray enough that you have to grind it down flat. It is one of the few jobs I contracted out. It is a nasty, messy job left best to the professionals-and I'm really glad I did. Good Luck, TomC
rip
« Reply #2 on: December 26, 2012, 05:06:34 AM »
I used a spray foam kit and did it myself. It is a very messy job and I agree with Tom, hire it out.  Don
FloridaCliff
"The Mighty GMC"
« Reply #3 on: December 26, 2012, 07:01:27 AM »
-EDIT-  misread ?
« Last Edit: December 26, 2012, 07:06:30 AM by FloridaCliff » Logged
Mark Twain
Giant Greenbrier Owner
« Reply #4 on: December 26, 2012, 02:04:36 PM »
Name??? -
Do you have a repair facility nearby that works on 18-wheeler trailers, especially reefers?  If so, go by and talk to the service manager and find out who does the spray foam for them.  Then set up an appointment to be there with the prepped coach the same day he's going to be doing trailers.  The pro will have all the necessary tools to do it right the first time, including smoothing it out for you.
This is one part of the conversion project that is well worth contracting out.  Best bang for the buck in the long run.
PS:  Please take a few minutes to update your profile with a signature line that includes at least your first name, home base city/state, make/model of coach and it's powertrain.  That way we can better help you by referring you to relatively local vendors, and you might just find out there are fellow busnuts in your area, too!  Welcome aboard!
Fresno CA
« Reply #5 on: December 26, 2012, 03:07:46 PM »
Any refrigeration trailer out fit like Great Dane will hot foam it, and hot foam if you are going to use foam is by far the best but if anyone in your family that is chemical sensitive stay away from foam it will cause problems to those people.
You need to seal around the up rights and roof brows if the spray gets behind those it will wave the siding and roof BTDT
« Last Edit: December 26, 2012, 04:07:48 PM by luvrbus » Logged
Midwilshire
« Reply #6 on: December 26, 2012, 05:33:09 PM »
It's definitely a do-it-yourself job and very easy to trim.  No joke; just watch the six youtube videos I posted in Reply # 36 in my "Introducting the Silverliner" bus project thread to see what's involved.  I'd link to it, but I don't know how.
Mike
Michael & Gigi
1978 MCI-5C "Silverliner"
Tampa, FL
boogiethecat
« Reply #7 on: December 26, 2012, 06:27:38 PM »
I used two-part foam from Mcmaster-carr http://www.mcmaster.com/#spray-foam-insulation/=krn3n6 the $831 ones, took two to do the whole bus (walls and roof)
For trimming I made this really safe tool (haha) Cheesy that I used with my big Milwaukee angle grinder
It works REALLY well to do the trimming but I have to say at 10,000 RPM it's pretty  ****ing scary....
« Last Edit: December 26, 2012, 06:29:38 PM by boogiethecat » Logged
1962 Crown
San Diego, Ca
« Reply #8 on: December 26, 2012, 06:49:59 PM »
The latest recommendations I've seen for spray insulation for houses is to use a cold applied spray foam instead of hot applied.  The hot applied foam can shrink as it cools and cures leaving gaps.  The rim joists in my house were spray foamed in 2001 during construction.  Cracks developed in the foam all over.  I had the insulation company come back, but all they did was fill the cracks with a can of spray foam.
chazwood
« Reply #9 on: December 26, 2012, 07:09:02 PM »
It will squeak
1992 MCI 102c3
Cummins l10 / Allison auto
Thekempters.com
Darkspeed
« Reply #10 on: December 26, 2012, 07:39:02 PM »
this is how i did mine..
used the E-84 fire rated foam
http://www.sprayfoamdirect.com/products/new-anti-microbial-formula/foam-it-602-anti-microbial-polyurethane-spray-foam-kit-detail
« Last Edit: December 26, 2012, 07:41:59 PM by Darkspeed » Logged
Todd
4106-1070 6v71 VH
« Reply #11 on: December 26, 2012, 10:17:31 PM »
The whole reason for using spray foam is that it sticks to the walls making everything tighter and I can tell you it does not squeak. Now use foam blocks cut to size-I can see those squeaking. Good Luck, TomC
chazwood
« Reply #12 on: December 27, 2012, 06:00:20 AM »
Mine squeaks
1992 MCI 102c3
Thekempters.com
chazwood
« Reply #13 on: December 27, 2012, 06:00:50 AM »
Every time you hit a bump
1992 MCI 102c3
Thekempters.com
chazwood
« Reply #14 on: December 27, 2012, 06:01:15 AM »
Just sayin'
1992 MCI 102c3
Thekempters.com
