May 18, 2013, 04:40:39 AM *
Author Topic: Blue Flame Heater  (Read 623 times)
Tikvah
« on: January 01, 2013, 06:23:55 AM »
I was thinking about picking up one of these heaters.  But, it says: Propane use requires 100-lb. tank or larger with two-stage adjustable regulator available from gas supply company.
Why can't I use this with 30lb bottles?
I couldn't repair my brakes, so I made my horn louder.
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
Cheboygan, Michigan (near the Mackinaw Bridge)
Slow Rider
« Reply #1 on: January 01, 2013, 06:52:33 AM »
From Northern Tool's website:
What size propane tank does this item require?
by   Anonymous   November 19, 2010
Answer this Question
Staff Answer
To prevent performance problems, do not use propane/LP fuel tank of less than 100 lbs. capacity.
by ProductExpert27 November 22, 2010
Vote:01
You can use anything from a 5 gallon tank to a 30 gallon tank. We have personally used 5 ,7,10, and 30 gallon tanks.
by  SouthernMama  - Pearce, AZ November 23, 2010
Vote:01
A minimum of 100# tank is recommended, but a smaller one would work, you will just have to fill it more often.
by  Brimac  - Olympic Peninsula, WA November 23, 2010
Vote:30
100 lb tank is the minimum size for this heater
by  oldchevy  - lewistown PA November 23, 2010
Vote:02
So according to NT it is a performance issue.  It does state the heater uses 1.38 pounds per hour on full burn.
If you decide to get one let us know how it works out.
Frank
Yes I am a BUSNUT
1976 MCI MC8
« Reply #2 on: January 01, 2013, 07:50:08 AM »
opinion:100lb is a safety factor for them.  your only suppose to fill 80% capacity.  by the way; what happens hen it gets 3/4 empty?  I used 20lb tank and lasted about 8hrs on 40,00btu model in 20F weather no insulation to speak of in bus when first starting.--was  insulating bus in winter. Propane is around 4.4 or 4.6 lb per gal if memory serves me correct and a standard grill tank holds under 4 gal. aprox.   FWIW
sommersed
« Reply #3 on: January 01, 2013, 10:33:32 AM »
That is the exact same Blue Flame that I have in my 5A.  Mine does not know the source of the propane, only that I supply it, I use three 7 gallon bottles as a supply system.
I like it because it is thermostat controlled.  The unit I had before this one had no thermostat, and I was constantly force out of my nice comfy chair to manually control it.
Ed
Utahclaimjumper
« Reply #4 on: January 01, 2013, 10:55:39 AM »
I have two of these,, they work well. Allways crack a window when used in an enclosed area to replace oxygen that is displaced from the combustion process,, they all have and advertise an "oxygen depletion sensor",, in fact it is only a thermocouple that shuts off when the oxygen level gets too low to support a flame,, by then its dangerously low.>>>Dan
Utahclaimjumper
 EX 4106 (presently SOB)
Cedar City, Ut.
« Reply #5 on: January 01, 2013, 11:38:58 AM »
I wonder if one of the issues is a smaller tank freezing up?  Our Boy Scout troop uses mostly 5 lb propane tanks.  We used a 5 lb tank with a high BTU three burner stove once.  The 5 lb tank eventually froze up and we had to switch to a 20 lb tank.
chessie4905
« Reply #6 on: January 01, 2013, 01:02:52 PM »
only use that blue flame heater in hot weather with a 30 lb tank and you should have no issues.
Utahclaimjumper
« Reply #7 on: January 01, 2013, 02:17:34 PM »
What would you use a flame type heater for in hot weather??>>>Dan
Utahclaimjumper
Cedar City, Ut.
gulfyankee
« Reply #8 on: January 01, 2013, 03:41:13 PM »
We have a 10000 btu unit in our 1000 sqft mobile home. It's kept our home at 70 inside when it got down to 25 outside. Propane line is routed thru the floor outside. We run it off of 20 lb tanks without a problem. One tank last approx. 52 hrs on high. Plan on putting a similar thermostat controlled model in the bus when i get to building the interior. Hope this helps.
« Last Edit: January 01, 2013, 03:43:57 PM by gulfyankee » Logged
Scott
Based out of Jasper, TX, but am hardly ever there
1958 GMC PD4104-2345
DD 6-71
Spicer 4 speed
chessie4905
« Reply #9 on: January 01, 2013, 06:45:37 PM »
the freezing up issue will usually crop up after tank gets to about 1/2 if you are drawing enough. As it starts freezing, the pressure starts dropping, and I imagine it could get to the point of incomplete combustion or flame out with gas seeping out after pressure starts to climb from tank normalizing.(thawing) Less chance of a problem with the big tank.
