June 19, 2018, 11:05:40 PM *
Author Topic: Good Macerator pump for a decent cost?  (Read 2790 times)
Oregonconversion
« on: January 08, 2013, 04:19:52 PM »
I am looking for a macerator pump that does not cost $250 or more. Is there a quality one out there for $100-$150 range online? It will be through a 75' garden hose from my black/grey combo tank.
1977 MC8
8V92 HT740
chessie4905
« Reply #1 on: January 08, 2013, 05:13:07 PM »
We had some good posts with pictures last year on using a garbage disposer for a macerator unit with good results. Should be able to access the info on a search or others will shortly chime in.
GMC h8h 649#028 (4905)
Pennsylvania-central
Oregonconversion
« Reply #2 on: January 08, 2013, 05:59:30 PM »
I do not have time to build one. Looking for pre made.
1977 MC8
8V92 HT740
Geoff
« Reply #3 on: January 08, 2013, 06:27:56 PM »
Series # 18590 Self Priming Macerator Pump
The plastic intake end will fit a 3" sewer hose.  Mine has the pipe end cut off.  I've been using it for 12 years.
--Geoff
Geoff
'82 RTS AZ
Oregonconversion
« Reply #4 on: January 08, 2013, 10:32:53 PM »
Is this a good price for it?
http://www.anchorexpress.com/jabsco-sealed-macerator-self-priming-pump-18590-2092/
1977 MC8
8V92 HT740
Oregonconversion
« Reply #5 on: January 08, 2013, 10:41:14 PM »
How do I hook that one up to my black tank? I was looking at one like this
1977 MC8
8V92 HT740
« Reply #6 on: January 09, 2013, 03:14:00 AM »
The Jabsco pump shown is designed to be permanently installed with ABS pipe in a marine application where the tanks are a bit harder to get at.
sommersed
« Reply #7 on: January 09, 2013, 05:46:58 AM »
I get mine on ebay, and I get the 24 volt macerator pump for they are far superior to the 12 volt ones.
Ed
« Reply #8 on: January 09, 2013, 09:14:43 AM »
We have a 12v one that, like the picture above, bayonet mounts to the disposal fitting.  We have used it a bunch of times, and it works great.  I still prefer direct gravity dumping, but if that is not possible we have a backup.
« Reply #9 on: January 09, 2013, 12:22:20 PM »
I have destroyed 2 of the Flow/Jet the newer ones have plastic brush holders in the motor and if you run it to long the holder melts and it doesn't runs anymore
Flow/Jet replaced the unit the first time free so now I have 2 pcs of junk that no longer work and they won't sell me the holder only a complete motor for over a 100 bucks
