May 24, 2013, 05:18:07 PM *
Author Topic: Fast Idle on MC 9 8V71 engine  (Read 447 times)
berrybus
« on: January 09, 2013, 06:15:59 PM »
We recently put on an air throttle and we relocated the shutoff cylinder.  Do we need to relocate the fast idle cylinder?  We do not have jake brakes.
I guess my real question is just how important is the Fast Idle? Any suggestions?
Thanks again for any information!
"No man is a bus."
hargreaves
1987 MCI 102A3
« Reply #1 on: January 10, 2013, 02:04:36 PM »
Fast idle is mainly used for over the road A/C. It does help build air faster but thats no biggy.  Cheers Gerry.
« Reply #2 on: January 10, 2013, 02:05:21 PM »
It depends to some degree on where your fast idle cylinder is located.  Mine is part of the buffer screw (I do have jakes so there is also a jake switch in the deal) so it is completely separate from any other control on the governor like shut-down or throttle speed.  If you have it I would leave it.  It's main use is to speed the engine so that the OTR original air conditioning and heating system can run.  They draw too much current for the alternator to supply at low idle.  Without the AC, all I use mine for is to speed up the airing up process from a cold start.
1980 MCI MC-5C converted
Vintage race cars -
1978 Lola T440 Formula Ford
1972 NTM MK-4 B/SR
flynbanjo
« Reply #3 on: January 10, 2013, 06:05:37 PM »
The fast idle for diesel engines is used to keep the oil pressure up for extended idle times.  If you don't idle the engine for very long then it is not necessary to use.  If you intend to idle the engine for several minutes or longer then it would be necessary.
Steven
81 MCI MC9
Hudson, Florida
« Reply #4 on: January 10, 2013, 06:29:40 PM »
Yea, it is kind of nice to see some oil pressure at fast idle. I hate it when I see no pressure at slow idle when hot. I guess there has to be at least 8 psi, or the safety feature would shut it down, but still.
Invermere, BC
« Reply #5 on: January 10, 2013, 10:24:31 PM »
I took my fast idle out when I put in the Jake brake-chose not to use the very expensive double fast idle/Jake brake switch. I have a King Cruise control that works just fine as a fast idle. Good Luck, TomC
