June 20, 2013, 02:30:30 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: looking for the best repower  (Read 2653 times)
Homegrowndiesel
Vegetable oil, Rudolf Diesel's original fuel
73-05 Eagle
« Reply #30 on: January 25, 2013, 04:47:40 PM »
I struggle with the same issues. The sled runs should take care of your need for speed.
trailconditions.com
I cranked up our 871 to 2400. went from 62 to 72 mph,, yea,,, i would like to be cranking 13, 14oo and be running 75-80 mph. yea the electronics and proprietary software to run these engines is where it is at. I want the double overdrive also.
Aerodynamic Eagle & 102a3
sledhead
« Reply #31 on: January 26, 2013, 02:46:26 PM »
Thanks for all the replies ,sorry I didn't get back to you sooner as we were on the road. We just came back to huntsville ont canada .Cold and snow ,had to wash off all the salt $#!% from the drive Sad  Now a problem with heat yes heat ! on the drive from florida I couldnt get temp. over 140-150 f ? I had to jerry-rig my shutters to a switch on the dash and close and open manually to get the temp up to 180f . Outside temp. was as low as 19 f on fri. morning . And to top it off my electronic heat on the bus (red degital read out push botton ) so no heat out of defroster or main heater.( only worked 2 out of 10 times I tried ) , so the floor heat was not as hot as it should have bean and the propane wall heat helped to keep the front warm . Is there a manual heat unit for this bus ? IN the fall I replaced the thermostats for new 170 f ( org were only 2 years old when eng. was rebuilt) Now I installed new ones same as org. t stats could they be in backwards ? Or can they stick open ? since rebuild eng. has run cold . Frustrated as heck!
      thanks    dave
Electman
« Reply #32 on: April 11, 2013, 08:35:37 PM »
Your best bet is an 8V92 DDECIII with a WTECIII HD 6 speed transmission, as a series 60 will be too tall and too long for your chassis.
Global Industrial Automatics does the complete conversions in Tucson, AZ
Hard Headed Ken
« Reply #33 on: April 12, 2013, 04:50:31 AM »
The height is OK but the length is a challenge.
Ken
« Reply #34 on: April 12, 2013, 05:00:06 AM »
Height is the problem in a Eagle the length is fine all re powers have something to work around in older buses takes a strong will  and mind to do one plus $$$$
« Reply #35 on: April 12, 2013, 08:24:34 AM »
Look at the Cummins ISL. It is available up to 450hp and 1250lb/ft torque-then you can use the shorter 3000MH Allison transmission. I would stay away from any 2 stroke engine for a repower-just not enough good mechanics left that know how to work on the 2 stroke engines. Good Luck, TomC
Pages: 1 2 [3]  All   Go Up
