May 25, 2013, 04:56:33 PM *
Author Topic: HT740 problem  (Read 580 times)
MC8Mike
« on: February 13, 2013, 04:18:55 PM »
I need some help from the Allison experts. I did a service on my trans today and three small aluminum ears were floating around in the pan. They were all broken the same. Not much other debris, where the heck did they come from? I took a picture of them but can't get it to post for some reason. Thanks for any help
1973 MC8 in progress but we're going to use it this year!
Fallon, Nevada
Dave5Cs
« Reply #1 on: February 13, 2013, 04:56:29 PM »
Came from the US mint!... Sorry couldn't resist. Cheesy
wow not good to find pieces of gear teeth which those look like. May be from your tail gears splines, I'm just guessing but is definitely good you have them out. Do you have any problems you have noticed with shifting or noises?.
Dave5Cs
MC8Mike
« Reply #2 on: February 13, 2013, 05:19:55 PM »
No, no noises. It functions pretty well but has a bit of a lazy shift between 2-3. That is what prompted me to do a service and see what was in the pan. They are not gear teeth, look to be some kind of a dog off an aluminum part.
Fallon, Nevada
Utahclaimjumper
« Reply #3 on: February 13, 2013, 06:06:55 PM »
 They appear to be SAWED off, not broken off.>>>Dan
Utahclaimjumper
 EX 4106 (presently SOB)
Cedar City, Ut.
Dave5Cs
« Reply #4 on: February 13, 2013, 06:17:15 PM »
sounds like they may be part of the second gear area
MC8Mike
« Reply #5 on: February 14, 2013, 05:11:51 AM »
No they are not sawed off, the piece on the left in the pic shows broken off and all three are the same. The area that looks sawed is a machine finish.
Fallon, Nevada
Boomer
« Reply #6 on: February 14, 2013, 05:41:44 AM »
Might try to email the pics to AZ Transmission they can tell you.
'81 Eagle 15/45
'47 GM PD3751-438
'65 Crown Atomic
Vancouver, WA USA
MC8Mike
« Reply #7 on: February 14, 2013, 07:07:45 AM »
That's a good idea, thanks for the suggestion.
Fallon, Nevada
Don Fairchild
« Reply #8 on: February 14, 2013, 07:58:46 AM »
sorry to say but those are out of a clutch pac. Probably the forward clutch,
Don
Scott Bennett
Scott & Heather MCI-9
Scott & Heather
« Reply #9 on: February 14, 2013, 08:56:41 AM »
Don
That's what they look like to me too.  Sad  Here's a shot of what we might be seeing?? Not a tranny expert:
Scott & Heather
« Reply #10 on: February 14, 2013, 11:03:30 AM »
It looks like the drive hub between the forward pack and the fourth gear clutch pack it a cast aluminum with the same look of the plates
MC8Mike
« Reply #11 on: February 14, 2013, 12:27:58 PM »
Looks like I'll be tearing it down sooner than later. Broken pieces floating around in a trans is never good. Thanks for the replies.
Fallon, Nevada
