May 20, 2013, 08:05:29 AM *
Author Topic: 8V71NA Muffler  (Read 551 times)
jetart
« on: February 14, 2013, 08:43:52 PM »
Hello,
I was backing my rig up and caught the curb side muffler tip in some terra firma.  The muffler twisted backward and is now completely vertical. Ha -  It's nice to know I have room in the engine compartment for such mischief.   I did not appear to damage the exhaust manifold which is great but I'll need to replace some tubing and the muffler.  Does anyone have a good source for the muffler? I did not see a P/N on the one I destroyed or the one that's still horizontal on the driver side (which curiously has slightly different dimensions) Any help / recommendations would be much appreciated.
Thank you!
82 Prevost 8v71NA mechanical.
'82 Prevost LeMirage XL, 8V71NA, 6 speed Spicer, converter unknown
« Reply #1 on: February 14, 2013, 08:48:28 PM »
Donaldson makes numerous mufflers-can go to the site and pretty much pick out your own muffler. Can order them from a big truck dealership that handles Donaldson. Will cheaper then Prevost. Good Luck, TomC
jetart
« Reply #2 on: February 14, 2013, 08:57:43 PM »
Thank you Tom!
chessie4905
« Reply #3 on: February 15, 2013, 01:25:27 AM »
here: http://www.donaldson.com/en/exhaust/support/datalibrary/061237.pdf
jetart
« Reply #4 on: May 02, 2013, 12:52:40 PM »
Got it done.  As suggested I went to the big truck dealer with my old muffler and we found it in the Donaldson book - however, it was backordered (possibly for months).  The very helpful counter guy suggested if I was in a hurry to try local hot rod exhaust shop.  The hot rod shop owner made a quick call and had one the next day.  He also helped sort out the bent piping and expand / weld my new round tube to the square DD exhaust manifold. He definitely had the "right" tools for this job..... All done for about $200.
Dan
« Reply #5 on: May 02, 2013, 10:24:50 PM »
Hopefully you still used the Donaldson muffler, and not a high performance muffler for a gasoline engine. Mufflers designed for gasoline are not right for Diesel engines. Good Luck, TomC
jetart
« Reply #6 on: May 03, 2013, 08:35:28 AM »
I did not ask the brand.  He said it was for a truck.  I looked inside from both ends and the construction looks the same as the one I replaced.
Dan
