February 24, 2018, 12:36:37 AM *
Author Topic: how to tell a 6v71t from a 6v92t?  (Read 1968 times)
Darkspeed
« on: March 17, 2013, 06:48:44 PM »
is there an easy way?
valve covers?
4106 6V92TA MUI + V730 8" Lowered Floor & Polished > http://www.busconversions.com/bbs/index.php?topic=24673.0 QuietBox > http://www.busconversions.com/bbs/index.php?topic=29946.0
It's all math and metal...
« Reply #1 on: March 17, 2013, 06:54:06 PM »
Look at the camshaft pulley it will have the model embossed like 6v71 or 6v92 more important make sure it is a silver engine model not the early green model
The silver 6v92 engine starts at serial number F83425 anything below that don't buy it
« Last Edit: March 17, 2013, 07:08:13 PM by luvrbus » Logged
Darkspeed
« Reply #2 on: March 17, 2013, 07:08:22 PM »
Thank you and how do i tell if its an early green if its repainted?
Darkspeed
« Reply #3 on: March 17, 2013, 07:09:09 PM »
got it thanks
why no green?
« Last Edit: March 17, 2013, 07:12:12 PM by Darkspeed » Logged
Darkspeed
« Reply #4 on: March 17, 2013, 07:14:02 PM »
do all DD have serial numbers?
Timkar
« Reply #5 on: March 17, 2013, 07:22:51 PM »
As far as I know..Here is some info for you, if interested
http://www.powerlinecomponents.com/detroit_info.htm
Cawston, British Columbia
Darkspeed
« Reply #6 on: March 17, 2013, 07:34:59 PM »
thank you
« Reply #7 on: March 17, 2013, 09:38:48 PM »
Two other ways-92 series has 92 cast into the block on the front top next to the head (can't remember if it is the right or left). Also, if you remove the valve cover, 71 series exhaust valves are arranged in a square arrangement. 92 series has the bottom valves wider then the top. Good luck, TomC
Darkspeed
« Reply #8 on: March 18, 2013, 08:02:49 AM »
Thanks Tomc
