May 25, 2018, 11:15:52 PM *
Author Topic: Air vs hydraulic cylinders???  (Read 10065 times)
« on: March 22, 2013, 06:14:34 AM »
I had a question about the difference between air cylinders vs hydraulic cylinders.  Hydraulic cylinders are easy to find, cheap as chips, many different sizes and configurations, rated to 3,000 psi usually.  Air cylinders are a lot harder to find, a lot more expensive, and I only need 150 psi for the bus maximum.  Is it possible to take a hydraulic cylinder and use it with air pressure?  What are the key internal differences to think about?  I am thinking of two applications off the top of my head - MCI style clutch assist, which is single acting, and door open/close which is double acting.
Thanks, Brian
bansil
« Reply #1 on: March 22, 2013, 08:56:05 AM »
how much stroke do you need for the door?
Doug
Mnt City TN
 Member of:
PP
Will & Wife
« Reply #2 on: March 22, 2013, 09:20:37 AM »
Air volume moves much faster than hydraulic oil and the seals on a hydraulic cylinder are fabricated with oil in mind. If you run them dry, they won't last long. I know that first hand from working on heavy equipment. Of course, that was many years ago and seal technology has probably changed.
Will Cheesy
OneLapper
« Reply #3 on: March 22, 2013, 10:45:58 AM »
Brian,
I'm looking into the clutch assist thing too.  I think air is going to be the way to go. I thought about using the power steering pump for the hydraulic assist cylinder on the clutch.  The air assist is probably cheaper in the long run since you don't need expensive hydraulic hoses, control valves, and return to sump setup.  Fluid flow regulators are more expensive.  I would also think that fluid viscosity (cold to hot) would affect the assist quite a bit.  The air assist would be more consistent.
OneLapper
1964 PD4106-2853
www.markdavia.com
« Reply #4 on: March 22, 2013, 12:43:46 PM »
Why not just go to a truck wrecking yard and buy the master cylinder and slave cylinder off a truck or buy the setup off a wrecked Prevost they have used it for years then you don't have all the design time and a proven unit
« Reply #5 on: March 22, 2013, 12:55:27 PM »
To be clear, I am asking if I can substitute a hydraulic cylinder that would normally use oil in an application that would use air.  I can get a 2" bore 8" stroke hydraulic cylinder with the fittings I need down the street for almost free (just as an example), while an air cylinder I would have to spec out and special order from the internet.  So I wondered - can I get one of the hydraulic cylinders and just use it with air instead of pressurized oil?
I don't know what stroke I need for the door yet, I haven't designed the system (custom retrofit deal).  Probably the 2" bore 8" stroke would work, developing around 350 pounds of push maximum, probably use a bleed to control speed and a regulator to control push.  Double acting so it both opens and closes.  Skinner valves so it is electrically controlled.  That sort of thing...
bansil
« Reply #6 on: March 22, 2013, 02:10:41 PM »
I wouldn't use a hydraulic cylinder for air,the big thing is volume vs pressure and sealing issues with air vs hydraulic the hydro cylinder is big and bulky and ugly....unless you need it  Tongue
FYI a skool bus door opener (air) is a 5-3/8 stroke (atleast the 2 I have) with cleavice pin mounts and both ends are adjustible about 3/8 or 1/2 in and they allow a closed position to over 50* opening using the stock retro fitted mounts.
should be a $10 JY find
More is possible, if you optimize the angles etc.
As for strength?.. you cant push the door open when it's closed (i converted mine from folding bi-fold; to 1 pc swing open)
Doug
Mnt City TN
 Member of:
chessie4905
« Reply #7 on: March 22, 2013, 02:25:27 PM »
My ACFBrill had an air(pneumatic) cylinder on the door. It was ok, but check out these item/s on Ebay: 24 volt linear actuators in different strokes. 12 volt also. Reversible.
GMC h8h 649#028 (4905)
Pennsylvania-central
Dave5Cs
« Reply #8 on: March 22, 2013, 03:11:27 PM »
Just thinking that there are air over hydrolic jacks like the 20 ton ones most of us have. don't they work with air pushing hydrolic fluid.
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #9 on: March 22, 2013, 06:26:00 PM »
They are two different animals for their specific application. Air works fine without a lot of load. Hydraulic is better and easier controlled. It really depends on your application.
I have used a lot of both in my previous life. Hydraulic is best for extreme condition, higher pressure and constantly lubricated. Best to control speed on the return side to maintain smoothness.
« Reply #10 on: March 22, 2013, 06:35:58 PM »
. . .  I'm looking into the clutch assist thing too.
Mark -
Do you not have the "mousetrap" on your 4106's clutch linkage?
Properly set-up & adjusted, it makes the clutch as light as a VWs.
NEWELL in South Carolina
« Reply #11 on: March 22, 2013, 07:33:33 PM »
Hydraulic cylinders are built heavier to withstand higher pressures possible with hydraulic fluid. If you add an inline pneumatic lubricator, a hyd cylinder should be fine with air.
Air cylinders usually have a very low "break away" force, so you should check the hyd cylinder to ensure it is acceptable. (Break away force = psi required to overcome the static friction of the seals.)
The real test is in connecting the hyd cylinder to compressed air & seeing that it moves as expected. Connect air to one port only & see if any leaks out the other port, if not, then you are good to go.
Let us know how it works out.
Brassman
« Reply #12 on: March 22, 2013, 09:27:07 PM »
In a piston-in-cylinder actuator, the force applied equals the pressure on the piston multiplied by the area of the piston. Off hand I'd say that a hydraulic actuator used at normal compressed air system pressure would cost much more than a comparable air cylinder. The hydraulic cylinder would be designed for thousands of psi, not hundreds.
hargreaves
1987 MCI 102A3
« Reply #13 on: March 22, 2013, 09:38:47 PM »
I have the air system of off the front door of my 102A3 you can have. You just have to pay the shipping from B.C.  Cheers Gerry
Darkspeed
« Reply #14 on: March 23, 2013, 05:29:01 AM »
a Hydraulic piston as a door actuator seems very dangerous, you could probably create enough force to crush someone.
Look for a 12v actuator like http://www.dcactuators.com/
4106 6V92TA MUI + V730 8" Lowered Floor & Polished > http://www.busconversions.com/bbs/index.php?topic=24673.0 QuietBox > http://www.busconversions.com/bbs/index.php?topic=29946.0
It's all math and metal...
