January 16, 2018, 09:24:34 PM *
Author Topic: Bad Fuel  (Read 2760 times)
rdbishop
« on: March 24, 2013, 06:41:46 AM »
What's the best way to get alge out of the fuel tank? Can the fuel be saved?
MysteryBus
1965 GM 4106 8v71 4 speed Spincer
« Reply #1 on: March 24, 2013, 08:14:40 AM »
If I'm not mistaken diesel should burn up any algae. If you empty the bio-diesel out, and run reg diesel though it should clean it out. I have also Heard if you use bio-fuel for the first time, you need to change the fuel filter several times because it also cleans out residue let over from reg. also burns cleaner and doesn't smell as heavy.
I mean it, youve got a nice place. Its not
 every man that can live off the land, you know.
 You do your own thing in your own time.
 You should be proud. - Captain America Wink
rdbishop
« Reply #2 on: March 24, 2013, 08:52:23 AM »
Sorry MysteryBus, I should have been clear as to the fact that it is reg, diesel in the tank.The old fuel had probably been there for some as the fuel has a blackish color to it and fills the fuel filter up fairly quick. The mech, at detroit diesel thought it might be alge whereas some thought it might be the inside of a fuel line breaking down.
sledhead
« Reply #3 on: March 24, 2013, 09:35:11 AM »
The black might just be old used motor oil put in the diesel tank.                     dave
dave , karen
« Reply #4 on: March 24, 2013, 01:20:55 PM »
Richard -
Try adding some "Bio-Bor" to the fuel tank, available thru West Marine and other vendors.
It "eats" the algae that lives in that separation line between diesel and any water that may have condensed into the bottom of the tank.
And as a precaution, always leave your coach parked with a full tank of fuel after a trip.  Reduces the potential for water condensation which leads to the algae growth.
Of course, spare fuel filters are a must!
« Reply #5 on: March 24, 2013, 01:31:22 PM »
Richard, even after you add a product like Sea Foam or Bio-Bor it has to be polished there should be someone in that area that will do that for 50 buck plus a few cents a gal how many gals are we talking about here
rdbishop
« Reply #6 on: March 24, 2013, 01:32:19 PM »
Thanks RJ, I'll give that a try. I hate to loose a full tank of fuel at todays prices. I just bought this bus and have no ideal how long it sat.
rdbishop
« Reply #7 on: March 24, 2013, 01:34:30 PM »
Hi Cliff, We're talking 144 gals. Explain polished?Huh
« Reply #8 on: March 24, 2013, 01:54:41 PM »
Best I can describe is a filtering system but if black it is a fungus not alge and a HTH tablet kills the fungus, alge needs sunlight to grow a fungus likes the dark
Just pump it through a couple of whole house filters then 5 or 10 micron fuel filter and it will clean up
rdbishop
« Reply #9 on: March 24, 2013, 08:45:09 PM »
OK Clifford, I'll try that....but what it an HTH tablet???
Dave5Cs
« Reply #10 on: March 25, 2013, 06:01:42 AM »
Clifford ya beat me to it. We have a big pond here at the ranch and every 5 months I spray it with algiside to basically provide a dark blacket that covers it and does not let light get to the water. The alge dies. So in the tank it can't be alge.
Dave5Cs from Galaxy S III
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
junkman42
« Reply #11 on: March 25, 2013, 10:36:43 AM »
If regular diesel  the black could be asphalt. I used to have that problem in boats Years ago!  Diesel conditioner will recombine it.
