June 21, 2018, 05:28:40 AM *
Author Topic: 8v92 on ebay  (Read 5413 times)
longjohn
« on: March 24, 2013, 02:03:36 PM »
Would this engine work in a conversion coach, it is supposed to be new but the no warranty clause is concerning.
http://www.ebay.com/itm/NEW-DETROIT-DIESEL-ENGINE-POWER-UNIT-8V-92TA-92-SERIES-BUS-MCI-PREVOST-EAGLE-GM-/360620790969?pt=Other_Vehicle_Parts&hash=item53f6ac94b9&vxp=mtr
John O
Eastern Shore of Maryland.
jmblake
Jason & Martha Blake
« Reply #1 on: March 24, 2013, 02:13:15 PM »
I also have seen that one listed for some time, Its only about 60 mile from me if you are interested I could try and find out more about the seller.
Jason
« Reply #2 on: March 24, 2013, 02:16:30 PM »
Maybe rebuilt but not new that is a sliver engine, crate engines never come with fram filters and painted manifolds or turbos with the electric shut down and air throttle I would say it's a military engine
« Last Edit: March 24, 2013, 02:20:19 PM by luvrbus » Logged
wg4t50
« Reply #3 on: March 24, 2013, 02:43:03 PM »
Agree, looks like the paint job was a major concern, if it a proper and correct rebuild, the price is not way out of line today. With 9200 injectors and better turbo, it would wake up.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #4 on: March 24, 2013, 03:53:06 PM »
military surplus  Known as Military Convoy  they have ongoing supply.
wg4t50
« Reply #5 on: March 24, 2013, 04:21:21 PM »
Yes, I got a surplus 8V-71 Large air box ports, had been used, but had new everything, then I paid $50.00 at auction and won, just shows the old saying is correct about the blind squirrel finding a nut every so often.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #6 on: March 24, 2013, 04:39:42 PM »
I noticed he did not post the model and application numbers that is a late model according to his serial numbers a 97 or 98 so you know it is not a bus or truck engine
« Reply #7 on: March 24, 2013, 09:27:43 PM »
Looks like a bus engine with the shallow oil pan and air throttle. Good Luck, TomC
Zeroclearance
« Reply #8 on: March 25, 2013, 11:02:38 AM »
Do you folks think that it's a brand new engine or factory rebuilt??   I wonder what kind of offers he has received?
saddleup
« Reply #9 on: March 25, 2013, 11:23:23 AM »
Zero, i see in his store, he has 8v92s for sale he calls new rebuilt..
Yuma,Az
Zeroclearance
« Reply #10 on: March 25, 2013, 11:31:48 AM »
Rebuilt, remanufactured isn't new..    If I was buying new I expect to have new castings.   Rebuilt cylinder heads that have run a million miles or idled for 15 years..
« Reply #11 on: March 25, 2013, 11:59:04 AM »
MTU (Motor and Turbine Union), the parent company of Freightliner and Detroit is still building the 8V-92TA (8V-71TA and 6V53TI) for the military. Unless it is a military engine, then it is a rebuild. Good Luck, TomC
« Reply #12 on: March 25, 2013, 05:43:13 PM »
With no warranty I would say that is Ace Hardware rebuild (paint) it doesn't have a bus oil pan the standard bus oil pans are sloped 3 inches deep in the front to 6 inches in the rear
It is not setup for a gear driven alternator or a power steering pump the adapter plate is missing who know what else is missing behind the covers it probably doesn't even have the right cam for alternator
« Last Edit: March 25, 2013, 06:09:19 PM by luvrbus » Logged
« Reply #13 on: March 25, 2013, 06:16:19 PM »
The E-bay store attached to posting sell military parts for humv etc FWIW
HB of CJ
« Reply #14 on: March 25, 2013, 07:40:20 PM »
Thanks for all of the knowledgeable replys just from looking at the photos.  Is 1600 pounds of torque accurate?  I dunno.  What do you think the mill is actually worth?  HB of CJ (old coot)
