May 27, 2018, 04:42:37 PM *
Author Topic: Canadian bus nuts, Princess Auto alert...  (Read 2741 times)
« on: April 04, 2013, 11:41:01 AM »
For Canadians who like to shop at Princess Auto, they have the trick 40:1 torque multiplier lug nut undooer on sale in the latest flier for $99.
Stormcloud
FMCA#407220
« Reply #1 on: April 04, 2013, 04:01:12 PM »
Thanks, Brian!  I haven't seen this weeks flyer yet.... Smiley
Mark
« Last Edit: April 05, 2013, 05:52:50 AM by Stormcloud » Logged
Mark Morgan
1972 MCI-7 'Papabus'
8v71N MT654 Automatic
sledhead
« Reply #2 on: April 05, 2013, 05:12:40 AM »
Hi Brian   I looked at princess auto but could not find it and I see that the 3/4" and the 1" torque wrench are not reversible .  http://www.princessauto.com/pal/product/8229239/Torque-Wrenches/1-in.-dr-Heavy-Duty-Click-Type-Torque-Wrench
I have been looking for a reversible one        thanks      dave
dave , karen
« Reply #3 on: April 05, 2013, 06:46:22 AM »
Dave, I have this one from Princess Auto:  http://www.princessauto.com/pal/product/8002384/Torque-Wrenches/3/4-in.-dr-Heavy-Duty-Click-Type-Torque-Wrench
It is not reversible in that it only clicks in one direction, but the instructions in the box tell you how to remove the two Phillips head screws that hold the ratchet mechanism into the head, and flip the mechanism over so it goes the other way.  That lets you torque in both directions with the click.  I do it all the time and while it takes longer than just flipping the lever, it's not all that bad.   It lets me do up the left hand thread nuts on my MCI.
Here is the other thing - it's a special buy, not a stock item so your store can order it but may not have it in stock.  http://www.princessauto.com/pal/product/8409450/Torque-Wrenches/Lug-Nut-Torque-Multiplier
« Last Edit: April 05, 2013, 07:54:21 AM by bevans6 » Logged
sledhead
« Reply #4 on: April 05, 2013, 02:59:30 PM »
Thanks Brian I called p.auto a year ago and asked them about the chance of the wrench working in reverse .They said no ! So now that I know it will work I will wait until they are on sale and get one   thanks again   dave
dave , karen
« Reply #5 on: April 05, 2013, 03:56:48 PM »
Another thankyou for Brian.  You should be on P.A. commission.  I've looked at their big torque wrenches and walked away for the same reason but I think I can handle that level of mechanical adjustment.
« Reply #6 on: April 06, 2013, 09:16:47 AM »
here are a couple of pic's in case what I am doing isn't clear.  Plus I am very bored, it is cold and snowing here and all my chores are outside, where I am not going to be today...
First pic is normal setup for RH thread  Second pic is all taken apart and third pic is with the 3/4" stubby reversed so the wrench will work backwards.  If you notice what you are actually doing is turning the wrench upside down, so to speak.  While this was covered in the instruction sheet that came with the wrench, I bet it works on all sorts of click type wrenches that only click in one direction.
« Last Edit: April 06, 2013, 09:23:08 AM by bevans6 » Logged
