June 29, 2017, 09:12:44 AM *
Author Topic: draining coolant 5A  (Read 1940 times)
codretaw1
1965 mci 5A south lyon, michigan
« on: April 04, 2013, 03:08:43 PM »
hi guys any tricks on drainig coolant from 8v71 replacing hoses and thermostats also flushing rads
« Reply #1 on: April 04, 2013, 04:17:58 PM »
My 5C has a drain plug on the lowest coolant tube leading towards the water pump.
« Reply #2 on: April 04, 2013, 04:44:18 PM »
Mine doesn't have a convenient plug. I remove a hose that is low and let it drain in a pan.
Blackie AB
« Reply #3 on: April 07, 2013, 11:02:10 AM »
When you refill, if you do it slowly and give the water time to settle down thru all of the lines, you can avoid having an air lock somewhere.  Smiley
« Reply #4 on: April 07, 2013, 11:09:04 AM »
Most should all have a drain plug at the bottom of the oil cooler on a 71 or 92 series or on the connection to it
codretaw1
« Reply #5 on: April 14, 2013, 12:21:57 PM »
thanks guys found drain at lower rad tube , all done new thermo stats and all new hoses
« Reply #6 on: April 14, 2013, 01:36:44 PM »
Make sure you open the tap on the cross-over tube between the two thermostat housings to let the air out.  You will probably find it takes a while for the coolant level to settle down as the air works it's way out of the engine.  You may have to bleed the driver's heater at the front of the bus if you got air in that system.
