February 20, 2018, 06:00:58 AM *
Author Topic: Cost to convert lugs from Stud Pilot to Hub Pilot?  (Read 7801 times)
grantgoold
« on: April 06, 2013, 03:59:37 PM »
Anyone have an idea of the cost to convert my wheels from Stud to Hub Pilot. Assuming I already have hub pilot rims and tires what kind of cost am I looking at changing the rims from steel stud pilot to aluminum hub pilot? I am looking at keeping the insider rear steel.  Seems like I would need 60 new studs and nuts.
I have an MCI 9.
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
flynbanjo
« Reply #1 on: April 06, 2013, 04:36:06 PM »
Not sure of the cost but you will also need six new hubs.
Steven
81 MCI MC9
Hudson, Florida
h1deout96a3
« Reply #2 on: April 06, 2013, 04:45:04 PM »
i believe you need to change to hub centered hubs as stud patends are not interchangable .      chuck L
« Reply #3 on: April 06, 2013, 05:49:56 PM »
The MCI 9 could have both hub or stud pilot wheels your hubs may work just check the measurements the center and bolt spacing
« Last Edit: April 06, 2013, 06:19:41 PM by luvrbus » Logged
chessie4905
« Reply #4 on: April 06, 2013, 06:09:21 PM »
 GMC (later models) came both ways. Hub wheel center diameter is the same. The hub piloted models are listed in MM, but dimension converts to same inch diameter on stud piloted hubs.
GMC h8h 649#028 (4905)
Pennsylvania-central
Dave5Cs
« Reply #5 on: April 07, 2013, 02:47:32 PM »
Grant, looks like under 300.00 for studs, Nuts and washers. Plus press out & in charges. That depends on so much per stud. If you have a good press you can do that yourself.
http://www.ryderfleetproducts.com/brake-and-wheel-parts-m-3203/hub-pilot-lug-nut-m22x1.5-33mm-hex-p-s46-m3203
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
grantgoold
« Reply #6 on: April 07, 2013, 04:28:12 PM »
Dave, are you saying that I can just replace the studs and nuts and keep the same wheel hub?
Grant
Grant Goold
1984 MCI 9
Dave5Cs
« Reply #7 on: April 08, 2013, 05:56:24 AM »
No you said in your post if you already had your wheels. Sorry hubs are different also. Thought you said you had them.
Dave5Cs from Galaxy S III
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
