January 19, 2018, 11:26:03 PM *
Author Topic: RV water pump  (Read 7184 times)
Tikvah
« on: April 09, 2013, 10:52:44 AM »
What do you like?
What PSI is best?
GPM?
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
Melbo
MC8 under construction
« Reply #1 on: April 09, 2013, 11:49:35 AM »
I have a flojet --- I don't know the model but has served well.
Doesn't need a pressure tank and we have no shortage of pressure.
I will operate on 24 or 12 volts.
HTH
Melbo
Oonrahnjay
« Reply #2 on: April 09, 2013, 11:50:26 AM »
     Same here.
« Reply #3 on: April 09, 2013, 12:57:58 PM »
I use 2 Shurflow Whisper Quiet pumps plumbed in parallel-meaning you can use either or both. I have both on when someone is taking a shower and dish washing is happening at the same time. It only puts out about 35psi-but it is more then enough.
I like the old style water pumps with mechanical pressure switches. I was at a RV show talking to the Shurflo factory rep, and he said the mechanical pressure switches (that are adjustable) are like a truck-very reliable. While the electronic variable speed are nice, he said that when they go out, they don't work at all. The Shurflo factory rep said he personally would take the mechanical pressure switch over the electronic. Good Luck, TomC
garhawk
« Reply #4 on: April 09, 2013, 04:30:33 PM »
Hi Tikvah,
Just replaced my Flojet with a new 3GPM and had the old one repaired for use as a spare.
The pumps are OK for the kitchen, toilet and sink but leave something to be desired in the shower.
I considered a higher pressure, high volume, 120 Volt pump from Lowe's - should have done just that!  The cost would have been near the same, longer warranty, and a real shower.
P.S.  Already had an expansion tank.
gary t'berry
Melbo
« Reply #5 on: April 09, 2013, 05:01:07 PM »
I have not had any issues with the flojet for the shower. As far as washing dishes when showering you can avoid that by getting the wife / girlfriend / partner in the shower with you AND it will save water. On the noise side -- the pump is close to the back of the bus and it does let us know when it is running. Just adds to the personality of the experience.
Melbo
« Reply #6 on: April 09, 2013, 05:42:06 PM »
Since we usually want to conserve water when running off the tank, it would seem that a higher flow pump is a disadvantage.
morefire
« Reply #7 on: April 09, 2013, 06:02:44 PM »
I love my Shurflo Extreme 5.7!!
I found a deal, and bought 3.  Only need 1 because of how powerful (65psi)  it is, but I keep the 2 others on my bay for spares.
http://www.shurflo.com/rv-products/rv-pumps/extreme-series-water-pumps/extreme-series-smart-sensor-57/default.html
« Last Edit: April 09, 2013, 06:05:03 PM by morefire » Logged
David G
Toronto, Ontario
2009 Bluebird 40' Coach
Cummins ISX-675HP!!
akroyaleagle
« Reply #8 on: April 09, 2013, 09:07:55 PM »
I have the same one as morefire. In fact I also got a deal on about 8 of them.
I plumbed 2 of them in so if one quits, I can just turn a valve and the other one picks up the load.
I can then repair or replace the other when it is convenient. Haven't had any trouble with these.
I use less water per shower with the high pressure. If I'm not hooked to water, We use navy showers.
We have 100 gal and quite comfortably go 5 days with showers every day. That's probably a little less
than 10 gal per day each. I do not want to use less and I think Momma would have a conniption if I
suggested it to her.
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
« Reply #9 on: April 10, 2013, 06:12:24 AM »
I have the Flojet Sensor VSD pump in my bus.  I bought a spare relatively cheap, but not really sure why I bought a spare.  The pump works quite well and I like that it works on 12 or 24 volt.
Sam 4106
« Reply #10 on: April 10, 2013, 08:54:23 AM »
We also use a Flojet sensor VSD 4.5 GPM pump. It provides all the water we need at 45 PSI.
Good luck, Sam
« Reply #11 on: April 11, 2013, 06:17:28 AM »
Aquajet pump.  Love it. 60 psi. Variable speed so you don't have to put a pressure tank in. I installed two 2-gal tanks anyway, and prefer it with the tanks
as opposed to without. The pump runs less often, but at full speed for short bursts, rather than running continuously on a low rumble during water use.
Make sure you get a screen and place in the supply line. We had an issue with teflon tape bits getting into the diaphragm before we installed the screen.
Cary and Don
« Reply #12 on: April 11, 2013, 09:13:40 AM »
We had a Shurflo 5.7.  It was a great pump. The pressure switch went out on it.  As it comes out,  this was a common problem. Guess what?  They don't have parts for the pump.  Buy a new model they say.  I explained that we probably had less than two full months of use on this pump even if it wasn't in warranty.  After a heated discussion they agreed to replace it with their "new improved smaller pump" for free.  I wouldn't buy another Shurflo product.
Don and Cary
1973 05 Eagle
Neoplan AN340
Iceni John
« Reply #13 on: April 11, 2013, 12:24:54 PM »
Like Tom, I have two SHURflo pumps in parallel, so I can use either or both as needed.   Mine are the simple old tried-and-trusted 2088-422-144 model  -  only 2.8 GPM, but by all accounts they go for ever, and are simple and cheap to fix if anything needs work.   A lot of pump failures are caused by FOD, so a strainer upstream of each pump is prudent.
I set my Watts 263A city water pressure regulator to the same 45 PSI as the pumps' output pressure.   I also have a strainer for the regulator to keep nasties out of it.
daveola
Galactic Bustastic!
Big Red and Little Red
« Reply #14 on: November 16, 2014, 04:08:23 PM »
I need to replace my FloJet VSD 4.5gpm that got destroyed by surprise freezing weather.
I have 24V DC and 110V AC available at all times in my rig, and I'm tempted to either:
1) Plumb two smaller pumps in parallel
2) Get a cheap 110V pump and switch and accumulator tank
If I put two smaller (say 3gpm) pumps in parallel, am I going to actually get 6 gpm out of them?
And for #2, any suggestions for a cheap switched 110V pump I can pickup?
I'd like to stay over 4 gpm and I'd like my pump to last longer, I've burned through 3 VSD pumps thanks to various issues.
