March 27, 2017, 05:23:40 PM *
Author Topic: question about tires  (Read 2492 times)
« on: November 22, 2006, 12:11:23 PM »
Got a potential deal working for some NEW never mounted tires. They have been in a climate controlled warehouse for 3 1/2 yrs.
My question is would they still be worth the trouble of buying and what would they worth to me OR you if you can use them?
The specs on them are as follows:
Brand    TOYO
Model    M124Z
Size       265.75R22.5
I can get a total of 14 of these here locally!
I also can get my hands on approx. 10 or so of mostly the same size (different brands) take offs which means they have about 3000 or so (not much more) miles on them. They all were for, or came off Large MH's to my understanding!
« Last Edit: November 22, 2006, 12:13:11 PM by Ace » Logged
« Reply #1 on: November 22, 2006, 12:28:06 PM »
Just received this information fromnthe TOYO web site if that helps!
 Toyo's Best Multi-Service, All Wheel Position Rib Radial
Suitable for the toughest local and regional haul applications, the full depth M-124Z provides long tread life and dependable service on local/regional steer, drive, or trailer applications where "high scrub" conditions are the norm.
Retail price from a generic dealer NOT mounted is $325.00 each
skihor
« Reply #2 on: November 22, 2006, 12:34:38 PM »
My tires are 12R/22.5 I don't know how that translates to the Toyo's. I might be interested in a pair of the Toyo's... I live in Colorado so I don't know about shipping. Or maybe Jim Sheppard would transport from a common rally you both are at??
Don & Sheila
tekebird
« Reply #3 on: November 22, 2006, 01:04:20 PM »
the 265 is a good bit smaller than a 12r22.5 if I recall
315 is larger.
if going metric you will want a 295 to be as close as possible
NEWELL in South Carolina
« Reply #4 on: November 22, 2006, 01:23:37 PM »
From what I've read;
If you are going to use them constantly, go for it.
If you are an infrequent user, they will age very fast & dry rot.
This is because of the plasticizers migrating to the surface when the tire sits still. If the tire is constantly exercised, the plasticizers migrate back in the rubber.
I don't know why or how this works, just personal experience backs it up.
YMMV
« Reply #5 on: November 22, 2006, 01:28:28 PM »
It would probably be a good idea to get the mfg data info off them and then get it translated into actual year of manufacture. Several people here on the board know how this works.
« Reply #6 on: November 22, 2006, 03:25:19 PM »
Ace- if you're thinking of using these tires for your bus, they are way too small.  They are rated at 10,410lb for the front and 19,220lb for tandem single axle.  Also, they are 38.7" in diameter (537rpm) compared to the 11R-24.5 that is 43.4" in diameter(475rpm). You'll be down rating your tires.  IMHO- you should stay with one of three tire sizes- 12R-22.5, 315/80R-22.5, or 11R24.5 16 ply.  265/75R-22.5 is what we use on our 26,000gvw trucks.  Good Luck, TomC
bruceknee
« Reply #7 on: November 22, 2006, 05:35:08 PM »
11r 225      41.8" dia
12r 225      42.6  dia
265 75 225  38.4 dia
« Reply #8 on: November 22, 2006, 05:38:38 PM »
Ok Thanks guys! That's exactly what I needed to know! I just didn't know whther this would be a good deal to purchase them or not and I guess from the looks of it that it I would be better off to Not get involved.
Thanks again...
bruceknee
« Reply #9 on: November 23, 2006, 05:37:53 AM »
Let me know what size tire you are looking for and I'll get you a price, it will be a good one
