January 17, 2018, 07:11:07 AM *
Author Topic: Replacing the Compressor  (Read 802 times)
Dave5Cs
« on: April 25, 2013, 09:18:37 PM »
Do you have to drain the whole system, oil and antifreeze when pulling the compressor on my MCI ,6V-71, or just below the compressor. The book sounds like all or just the compressor?
Also does anyone know what 740 Tranny takes in Gallons for a fluid change. I believe it is just ATF in mine because it is Red.
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #1 on: April 25, 2013, 11:16:15 PM »
You just have to drain enough coolant so the coolant is below the level of the compressor. You do not have to drain the oil-but most likely you'll get some coolant in the oil-hence you should change the oil afterwards. Good Luck, TomC
« Reply #2 on: April 26, 2013, 05:31:45 AM »
Dave the 740 takes 7.5 gals with the standard 5 inch pan + the filter and cooler most will be around 10 gals when done
Dave5Cs
« Reply #3 on: April 26, 2013, 05:36:43 AM »
Thanks Tom and Clifford the book was not clear on either.
Dave5Cs from Galaxy S III
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #4 on: April 26, 2013, 05:49:29 AM »
FWIW my NAPA store here as probably yours can order the pan gasket and the internal filter some 740's have a washable internal filter
