May 22, 2018, 02:56:42 PM *
Author Topic: New Favorite Bus Tool  (Read 4192 times)
Debo
« on: April 27, 2013, 05:45:58 AM »
Hi guys, first post as a new member to this board. I've had my '81 MC9 for about 5 years and have been a member over at the other board but just joined here. The archives at both places have been invaluable. But enough of that...
Three words - Electric Impact Wrench
I'm just completing a complete suspension overhaul of my bus - new air bags, radius rod bushings, shocks, etc. and this thing has been amazing. It's a Hitachi WR22SA. It's a 3/4" drive corded tool that develops about 500 ft/lbs of torque and draws about 7 amps. I say "about" because it will spin off lug nuts that I've torqued to 500, so I know it must be conservatively rated. Not cheap - around $360, but I wanted something I could use to remove wheel lugs on the side of the road (and other jobs) without worrying about air capacity or proximity to a compressor. Yes I know, now I need to worry about proximity to a power outlet, but those are a lot more common and I have a generator. I've bought a bunch of adapters so I can go to just about any size drive socket and get the job done. Make no mistake, this is a serious tool. Used on too small a fastener, it'll twist that sucker off like it ain't even there.
I wanted to post this because when I was considering impact guns, I immediately started thinking "air tool" without considering that there have been a lot of new technological developments. For me, this is a perfect solution. When re-installing my wheels, I start the nuts by hand, then spin 'em till the gun slows down, then torque them with a torque wrench. Takes about 5 minutes a wheel. It's also been a lifesaver with this radius rod bushing project.
For the record, I have no association with Hitachi or any interest in trying to sell anybody anything. Turns out they just make my new favorite bus tool.
Tailwinds...
1981 MCI MC9
Detroit 8V-71N
Spicer 4-Speed Manual
Outer Banks, NC (Nags Head)
Nineforever
Nineforever
100 klms south of Yellowknife NWT Canada
« Reply #1 on: April 27, 2013, 07:37:23 AM »
Makati makes a electric impact 1100 psi great for wheel nuts etc owned it about 5 years , just sent it out for repairs its been trouble free up till know.
Hyway 3 100 klms south of Yellowknife NWT Canada
« Reply #2 on: April 27, 2013, 11:08:06 AM »
I have had an electric impact wrench for about 25 years or so, it still works but is only good for 250-300 ft/lbs.  The one you have would be a nice upgrade.
« Reply #3 on: April 27, 2013, 01:19:29 PM »
I have a 1/2" drive air wrench that peaks at 600 lb-ft so I can't over torque the wheel nuts. I make the tire guys use it instead of their monsters since one stripped most of my studs on one wheel.
For nut removal I have a manual torque multiplier, works every time.
wg4t50
« Reply #4 on: April 27, 2013, 01:54:26 PM »
Nice to have good tools, me, I use a 3/4" air @ 180 psi, you guessed, it gets er done now.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #5 on: April 27, 2013, 04:55:45 PM »
Why not make them use a manual torque wrench instead?  I saw one at the tire dealer last year when I got two new steer tires.  I have my own 600 pound manual torque wrench I got for a steal from an online pawn shop last year.
Jnbroadbent
« Reply #6 on: April 27, 2013, 05:11:47 PM »
I've got a dewalt 1/2" impact, headache saver for sure. Only has 300 ft lbs or so. I need to upgrade before I get into the airbags.
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
« Reply #7 on: April 28, 2013, 07:50:01 PM »
Most of the tire guys around here don't even own a torque wrench!
My air wrench is not capable of over-torquing the nuts and I check them when I get home. Unfortunately my torque wrench won't read CCW so I stand on a 2' wrench pipe for those!
Debo
« Reply #8 on: May 01, 2013, 08:37:41 AM »
Funny you should say that. I discovered that my torque wrench doesn't read CCW either, so I have the same thing.
1981 MCI MC9
Detroit 8V-71N
« Reply #9 on: May 01, 2013, 08:52:35 AM »
What is CCW?
« Reply #10 on: May 01, 2013, 09:06:24 AM »
What is CCW?
Counterclockwise.  Some buses have left hand threaded studs on one side.  I have a Tireman torque wrench that you can change which side of the wrench the socket is on to handle left hand and right hand threads.
« Reply #11 on: May 01, 2013, 01:35:34 PM »
Oh.  The left side of mine has that.  I always have called it left handed threads.  Although my torque wrench can be reversed with a little dis-assembly, it doesn't go high enough anyway.  My weight three feet out on the bar seems close enough.
