April 22, 2018, 01:53:33 AM *
Author Topic: Battery - Why Not?  (Read 3665 times)
Tikvah
« on: May 02, 2013, 10:03:52 AM »
I'm trying to find a temporary solution.  I only use the bus a little for now, when we're ready to go full time we might need to upgrade.  Why won't a set of batteries like this work?   Maybe two or four?
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
« Reply #1 on: May 02, 2013, 10:13:43 AM »
Like what?
Tikvah
« Reply #2 on: May 02, 2013, 10:14:47 AM »
There are three pictures attached
1989 MCI-102 A3
Purplewillie
« Reply #3 on: May 02, 2013, 10:25:27 AM »
I only see 3 ? Attached
Mark & Char
1976 P8M4905a 8v71 v730
British Columbia Canada
wal1809
« Reply #4 on: May 02, 2013, 10:31:20 AM »
I see nothing
www.snakebreaker.com
Tikvah
« Reply #5 on: May 02, 2013, 11:15:14 AM »
I don't know why you guys can't see the pictures.  I can see them just fine.  maybe I should re-post my question.  Basically they are just Marine Batteries from Manards. They're on sale right now for $74.97
Exide
675  Marine Cranking Amps
182 Minutes Reserved Capacity
105 Amp hours @ 20 hours
1989 MCI-102 A3
« Reply #6 on: May 02, 2013, 11:22:19 AM »
Check with your local big truck dealership or parts house. I know we have size 31 925cca batteries for $80.00 each. Two will spin that engine just fine-in moderate weather. Good Luck, TomC
Tikvah
« Reply #7 on: May 02, 2013, 11:23:17 AM »
These are RV/Marine batteries.... looking at them for house batteries
1989 MCI-102 A3
« Reply #8 on: May 02, 2013, 11:41:14 AM »
Still can't see the pics, but as I understand it (which can be wrong), marine batteries are a compromise between start and deep cycle.  That would mean that they can be used for both but are not necessarily the best for either.  I would think that you could use them for your house batteries and, if you are merely using the house bank for light loads, they will do the job.  Deep cycle would just be better.
Tikvah
« Reply #9 on: May 02, 2013, 11:41:49 AM »
« Last Edit: May 02, 2013, 11:48:29 AM by Tikvah » Logged
1989 MCI-102 A3
Scott & Heather
MCI-9 & MCI-102
« Reply #10 on: May 02, 2013, 11:53:36 AM »
Now we can see them ! :-)
Sent from iPhone via Tapatalk
Scott & Heather
Seangie
www.herdofturtles.org
« Reply #11 on: May 02, 2013, 11:58:16 AM »
Tikvah,
Any battery will work as long as the battery has the correct voltage for the system and can handle the amount of amps pulled from it.  The difference will be how long they last and how well they work for you which comes down to make up of the battery, plate thickness, cost of battery.  You get what you pay for Wink
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
Don4107
« Reply #12 on: May 02, 2013, 12:06:03 PM »
How far are you from using the bus more?  A couple golf cart Trojans will cost more but perform much better and last lots longer if treated well.
Good luck
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
« Reply #13 on: May 02, 2013, 12:30:57 PM »
Just to throw in another factor.  If you can find good used or blem AGM's, you will bless the day you got them-- no watering, no acid crud, no peripheral corrosion, etc.
