May 24, 2018, 10:54:05 AM *
Author Topic: Help Trans will NOT go into reverse  (Read 2790 times)
4104bigred
« on: November 25, 2006, 07:52:30 AM »
hey guys my 4104 with a 4 speed spicer all of a sudden will not go into reverse. the solenoid is working properly and I have disconected the shift rods and I still can not get the 1-2 shift fork rod to slide toward the rear of the bus to get the thing into reverse.
any suggestions
thanks
chris
231 846 0880
« Reply #1 on: November 25, 2006, 04:07:13 PM »
Chris,
Have you chercked to see if you are stuck between gears, or if the transmission is actually already in second gear?
I believe on the 7141a that you have to have the shifter in neutral before the reverse solenoid will engage.
My 4103, (same transmission) will sometimes get stuck when I've tried shifting too quickly. It happens because the bushings are shot and I'm to lazy to replace them right now.
Good luck1
« Reply #2 on: November 25, 2006, 07:31:27 PM »
Chris,
I'll state the obvious just in case, but Reverse has to be done just exactly like this;
1.  Place trans in First.
2.  Push Reverse switch (on bottom left side of front left          panel) to the right.
3.  Hold this switch to the right.
4.  Move the shift lever to the Second gear position
5.  Release the switch.
6.  This should be Reverse
Mine sometimes sticks too or just doesn't go into Reverse but I just start over and it always works
keithshotrodshop
« Reply #3 on: November 25, 2006, 08:46:12 PM »
I had to hit mine with a hammer once to get it to work! I just had to tell it who the boss was Grin
« Reply #4 on: November 25, 2006, 10:04:23 PM »
I was told to put it in neutral, push switch then pull back to second to engage reverse. Otherwise you could burn up the solenoid.
Which way is correct?
« Reply #5 on: November 26, 2006, 05:36:47 AM »
From the 4104 manual
« Reply #6 on: November 26, 2006, 06:33:46 AM »
Len,
Thanks for the correct procedure.
brojcol
Jimmy
« Reply #7 on: November 26, 2006, 06:45:18 AM »
I had this happen to me once at a car wash.
I nearly panicked.  I had about three inches from the vacuum cleaners and it just wouldn't go into reverse.  So, I finally shut it down and started it up again.  Worked like a charm.  You might want to check on the reverse solenoid.
Jimmy
4104bigred
« Reply #8 on: November 26, 2006, 07:21:20 AM »
OK Guys  thanks for the replies,  turns out that the reverse solenoid has contacts on the back side under a cover. the small plunger at the rear (not the large plunger that pulls the tranny into reverse) was rusty and stuck also the contact point was burned off.
I put a stainless pop rivet in for a new contact and cleaned the plunger,bore and used corrosion x on and whalla perfect reverse
thanks again
