May 26, 2018, 08:46:25 PM *
Author Topic: Overfilled crankcase  (Read 4800 times)
Mike in GA
« on: May 08, 2013, 08:00:04 AM »
Have about a gallon too much oil in the 8v92. Don't ask how that happened.
     Which is more dangerous - ignoring it, or climbing underneath and loosening the oil filter to drain off the excess?
     Thanks for the usual fine suggestions!
Mike in GA
Past President, Southeast Bus Nuts. Busin' for more than 15 years in a 1985 MC 96a3 with DD 8v92 and a 5 speed Allison c/r.
« Reply #1 on: May 08, 2013, 08:20:28 AM »
Drain it a gal over put the rods in contact with the oil in the pan you will have a hella mess in about 50 miles
Utahclaimjumper
« Reply #2 on: May 08, 2013, 08:36:09 AM »
 Just crack the drain plug into a gallon bucket,, easy and messy ,, but needed.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Oonrahnjay
« Reply #3 on: May 08, 2013, 08:38:25 AM »
   Mike, do you have (or can you borrow from a friend) a vacuum oil extractor like this?  I bought it because it works really well on my VW diesel Jetta but after I owned it, I found that it was useful for many things.  (PS  This is way overpriced but I wanted a photo and it was the first one on Google.)
http://www.wholesalemarine.com/p/PEL-PL-6000/?utm_source=feed&utm_medium=cpc&utm_campaign=google&gclid=CP2ywrHthrcCFcw7OgodC04AQw
« Reply #4 on: May 08, 2013, 09:21:19 AM »
Since the oil in the pan is not under any pressure, it is easy to loosen the drain plug and let a gallon out.  If you should happen to loosen it too much and the plug comes out, you can just screw it back in. When I bought my Fumato drain valve, it installed it just that way with barely a cup of spillage, and 40 weight oil is a wonderful moisturizer.
« Reply #5 on: May 08, 2013, 09:26:17 AM »
Too bad that you don't have a Fumoto drain valve in place of the pan plug, easy to drain any amount out without needing a wrench or making a mess.  Grin
Iceni John
« Reply #6 on: May 08, 2013, 12:12:55 PM »
Yes, Fumotos are great.   They make jobs like this a breeze.   Just make sure it would not be the lowest thing above the ground!   Otherwise, hand-cranked transfer pumps are good for moving liquids, and there are also drill-powered versions that are quicker.
Mike in GA
« Reply #7 on: May 08, 2013, 01:16:06 PM »
Thanks everyone.
     Spent the middle afternoon under the bus, and the idea of loosening the oil drain plug worked great - didn't even drop it.
    Took a gallon out, and the oil dipstick is now on the money.
    Being the tightwad that I am, I even captured the barely used oil for use in topping off the crankcase in the year to come.
    The idea of a Fumoto drain valve is interesting.
Thanks again.
Mike in GA
Utahclaimjumper
« Reply #8 on: May 08, 2013, 01:31:33 PM »
 Another tip:: always check the oil after sitting overnite,,if you check it too soon after a run you will be "chasing" 1/2 gallon and be overfull..>>>Dan
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
« Reply #9 on: May 09, 2013, 01:34:22 PM »
Is the Fumoto drain the one with the little lever on it I have saw a bunch of Kemco No Spill systems but don't recall ever seeing a Fumoto valve
Scott & Heather
MCI-9 & MCI-102
« Reply #10 on: May 09, 2013, 03:15:38 PM »
Cliff:
Scott & Heather
Dave5Cs
« Reply #11 on: May 09, 2013, 09:31:27 PM »
Femco No spill  system is the other one Clifford.
I just ordered the Fumoto one, T 202N 1/2 14, with the nipple on it for a hose hook up. 42.00 with shipping Cool
Dave5Cs
« Last Edit: May 09, 2013, 09:32:59 PM by Dave5Cs » Logged
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #12 on: May 10, 2013, 05:09:03 AM »
Thanks Dave I didn't know the manufacture but Kemco sounded about right lol me I will stick with the old technology steel plug
« Reply #13 on: May 12, 2013, 09:52:30 PM »
4104 and 4107 manuals say to check the oil after sitting a few minutes after being driven.
« Reply #14 on: May 13, 2013, 03:18:12 AM »
I like the steel plug with the magnet too.  Old school, but I like seeing what sticks to the magnet.
