April 19, 2018, 10:20:13 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: 6v92ta verses 8v92ta  (Read 12528 times)
« Reply #30 on: May 13, 2013, 01:47:18 PM »
It was called a HT750DR or the HT754CR to differentiate the two. The DR did have a deep 1st gear that was NOT supposed to be shifted up to 2nd while moving. The new 4700RDS also has a deep low added to the 4000RDS that can be shifted full power. Good Luck, TomC
RickB
« Reply #31 on: May 13, 2013, 01:54:59 PM »
Tom, I have the 754 CRD and I can't believe that they would have a lower first gear than this. It is basically for climbing trees, Lol! Seriously, I've never looked at the MPH when I shift to 2nd but it has to be single digits. That's another thing is it win't shift out of 1rst automatically, you have to do it.
Rick
« Reply #32 on: May 13, 2013, 02:43:34 PM »
Rick as TomC pointed out the 740 and the 754 both have a 1st gear of 3:69 maybe you have a 750DR those are deep a 7:97 ratio almost like crawling basically all the 700 HT series are about the same except for the gearing then you have the V series
sledhead
« Reply #33 on: May 14, 2013, 05:09:13 AM »
Rick      I called yesturday but my guy was not in I will call to day and will let you know what eng.s they have                          dave
dave , karen
sledhead
« Reply #34 on: May 14, 2013, 07:48:28 AM »
I got a hold of the 5 speed trans. info . It is a 1993 ht755cr atec, it comes with the computer and the key pad . I have a 14 gage 12  wire harness that I can install from back to front.I was told I will need the tps or a tecl, the wire harness connector at the trans.                 Is this a good trans. for my 6v92ta and will I have any problems with the electronics?              thanks again for the help dave
« Last Edit: May 14, 2013, 11:24:11 AM by sledhead » Logged
dave , karen
sledhead
« Reply #35 on: May 15, 2013, 08:48:48 AM »
Rick b   I tried to send you a email    well that did't work  so if you could send me one I will respond. here is my email   crane66@hotmail.ca   or call 705  789  8189
  thanks  dave
dave , karen
Pages: 1 2 [3]  All   Go Up
