May 24, 2018, 04:45:37 PM *
Author Topic: MC-7 defroster motors  (Read 1291 times)
Emcemv
1973 MCI MC-7 Combo
« on: May 19, 2013, 11:19:29 AM »
I've started working on our defroster motors, they have been quite noisy and I'm pulling them both out to see if I can get some lube into the motor bearings.  I also found a couple of small rubber hoses connecting the defroster heater core to the pipes and these look like they are 40 years old so will replace those. Anyone know if the motors are still available or if there is a substitute?  I'm hoping a little lube will improve things but I am going to look around on the web to see if anything is available to replace them with.
I also discovered that you can't remove the left hand blower without removing the rubber hoses, you need to slide it to the right to get it out and it hanges up on the hoese and clamps.  I'm going to modify the blower outlet housing to fix that once I get it out.
Next, I have to get the front end of the bus up in the air so I can take the wheels off and go through the brakes and wheel bearings etc.  Got to learn how to adjust the brakes and check everything over.
Bruce & Nancy Fagley
1973 MCI MC-7 Combo Freighter
450HP DD 8V-92T 2000 Reman
HT 740 Allison
Woodbury CT.
« Reply #1 on: May 19, 2013, 11:58:59 AM »
Find a place that fixes small electrical motors and see if they need new bearings or brushes. Did mine a couple of years ago and i think it was something like 46 or 54 bucks for both motors.
Seangie
www.herdofturtles.org
« Reply #2 on: May 19, 2013, 12:16:05 PM »
Bruce -  I'd be surprised if an Alternator rebuild shop wouldn't be able so clean those up.
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
Emcemv
1973 MCI MC-7 Combo
« Reply #3 on: May 19, 2013, 06:43:05 PM »
Thanks Sean and Ed, we have a motor shop near us, may give that a shot.
HT 740 Allison
Woodbury CT.
Boomer
« Reply #4 on: May 19, 2013, 08:21:29 PM »
You can unscrew the brush retainer (the small round knurled knobs) and check the brushes and commutator for that part of it.  It will probably produce a lot of cussin' to get the scroll off the shaft so be ready for that. Remove set screw and soak with penetrant. Mohawk, MCI or Kirks Automotive should have reman exchange motors, probably the best way to go.  My bet is the brushes have not been changed for years.
HTH
Mark
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438
'65 Crown Atomic, NO MORE
Vancouver, WA USA
