February 23, 2018, 04:51:20 AM *
Author Topic: turbo drain tube?  (Read 5112 times)
« Reply #15 on: May 23, 2013, 09:50:49 AM »
Ok I buy that ::)the only 8v71TA I saw with a complete run made with a rubber hose was well done after the fire
« Reply #16 on: May 23, 2013, 10:05:56 AM »
Clifford, I posted a pic of the original turbo drain setup on my engine as it was supposed to be installed in the M110 Howitzer.  The turbo drain output on the turbo housing is a 2" long smooth tube stub, you are going to have to put a hose on it if only to couple to the metal tube extension.  I don't know how else to do it.  Now you have me all worried  Shocked
« Reply #17 on: May 23, 2013, 10:19:43 AM »
That engine had a rear drain ? I still never saw one like that it from DD it would scare me
« Reply #18 on: May 23, 2013, 12:14:11 PM »
The original drain tube location was into the accessory cover that was where a power steering pump would be on an MCI, the lower left-most drive position.
« Reply #19 on: May 23, 2013, 02:30:04 PM »
Bevans ;and others ck out bus projects I just started a progress post. pic are about 6 month old.  I lost about 9month due to back surgery. Finishing now.   Bob
« Reply #20 on: May 23, 2013, 02:52:13 PM »
looking forward to following that finishing!  My experience is that when you are 90% done you are half way there!
