February 18, 2018, 12:29:50 PM *
Author Topic: Where Does the Military Use Detroits  (Read 4040 times)
« on: May 27, 2013, 09:13:50 AM »
I have been talking to an ex Marine that still works on the base here in 29 Palms as a tank mechanic.  I got excited thinking that I had found a local 2-cycle man, but he says that he has not worked on Detroits.  He says the M1 Abrams has a turbine engine.  So does anyone know which military vehicles use a Detroit 2-cycle?
« Reply #1 on: May 27, 2013, 09:38:22 AM »
Lin, I see the engines in Howitzers.tenders,troop carriers,recovery vehicles and things I have no idea what they are lol here on Ft Hood you have young people here a Ft Hood that work on those babies
I just saw a train load being shipped from Ft Hood to NATO the 8v92 DDEC V with military programing they are replacing all the old 8v71 I was told
« Reply #2 on: May 27, 2013, 11:03:14 AM »
This guy has no experience with 2-strokes and never worked on a Detroit.  He did say that the vehicles used for tank recovery, which he did not work on, are 2-stroke but did not know if they were Detroit.  I don't suppose there are any other.  He said they had double turbos, and I think he mentioned that they were air cooled.  Does that make sense?
Anyway, I asked him to check around there and see if any of the 2-stroke guys was interested in outside work if I should need it.
« Reply #3 on: May 27, 2013, 11:26:24 AM »
They do have some type German made piece of equipment here that has the V10 Deutz twin turbo engine air cooled and I found out buy asking the Sheridan and Walker had DD and some with Allison engines
« Last Edit: May 27, 2013, 11:36:00 AM by luvrbus » Logged
« Reply #4 on: May 27, 2013, 12:04:40 PM »
6V-53 is used in a tracked troop carrier. 8V-92TA in various other equipment from 8x8 HMMT to troop carriers. 8V-71TA is also used still, not quite sure what equipment. Most military equipment is designed around the engine. It isn't possible to switch. But when they come out with a new model, it will have the most up to date engine.
Bradley tank still uses the Cummins VTA903 with air to air intercooling and electronic common rail fuel injection. They're getting about 700hp out of it, but only 1550lb/ft torque. The Bradley was designed around the Cummins VTA903. Good Luck, TomC
« Reply #5 on: May 27, 2013, 12:26:34 PM »
If it not possible to change power plants in Military equipment someone forgot to tell Stewart and Stevenson in Sealy Tx plus Tank Automotive in Warren MI and the Army I just read where there was 22 million dollars in contracts awarded between the 2 in the Ft Hood paper for that very purpose to update the engines but who knows
There are I would say 6 or 7 hundred Cat engines of different models in crates on the dock that were built in Sequin Tx at the Cat factory waiting to go somewhere you have any ideas what they are for TomC ?
« Last Edit: May 27, 2013, 12:38:03 PM by luvrbus » Logged
« Reply #6 on: May 27, 2013, 01:03:17 PM »
I did read where the Abrams tanks using a 1500hp Turbine was going to be replaced by a V-12 MTU putting out 1450hp. The transmission they're going to use-a tank transmission based on the HT740 Allison-one tough transmission. Good Luck, TomC
akroyaleagle
« Reply #7 on: May 27, 2013, 03:03:29 PM »
The military still uses 2 stroke Detroits in a lot of equipment.
Most I have seen in the last 25 years are 8V92 twin turbos.
Unless the guy works at the rebuild (depot) level, he won't know anything about the engine.
What the military calls mechanics just remove the engine and transmission (powerpack) and install a new one. Takes a short time. They put the removed powerpack in the can the new engine came in and turn it in.
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
Dave5Cs
« Reply #8 on: May 27, 2013, 07:05:32 PM »
Clifford;
Fort Hood, the wife says when she was in the ARMY 25 years ago stationed there, ago they called it, "The Hellhole of America", & " The Armpit of the ARMY", LOL Grin
Dave5Cs
« Last Edit: May 27, 2013, 07:20:22 PM by Dave5Cs » Logged
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
« Reply #9 on: May 27, 2013, 07:16:55 PM »
Sure is huge base Dave takes 1/2 day to drive across that sucker they do have a first class RV park here on the base for 10 bucks a night it looks like Phoenix with a convenience store every block It has changed over the years not a place I would won't to spend 25 years though
Dave5Cs
« Reply #10 on: May 27, 2013, 07:19:21 PM »
Clifford sorry she was there 25 years ago LOL for only 1 year and then off to Berlin.
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
Oonrahnjay
« Reply #11 on: May 27, 2013, 08:47:31 PM »
    Some spring times (forest fire season in NC), I work for the NC Forest Service.  We have a couple of Vietnam-era Armored Personnel Carriers that have had the back end cut off and a big water tank put on for fighting fires (mostly "mopping up" actually).  They call them "all-tracks".  The work great.  They have Detroit 2-strokes in them.  Our mechanics *DO* service them, engines in and out, complete rebuilds etc.  They absolutely hate them!
BH  NC   USA
Kwajdiver
MCI-9 "Kwaj Diver"
« Reply #12 on: May 29, 2013, 01:48:04 PM »
I was watching the movie PT-109 a couple days ago.  They showed the engine room of the PT-Boat.  Believe they had twin 12v71 or something close to that.
Bill
Busless
But still at Kwajalein
Auburndale, Florida
MCI-9
Kwajalein Atoll, RMI
wildbob24
« Reply #13 on: May 29, 2013, 01:57:33 PM »
I don't know what the movie boat used, but the original engines were V12 Packards.
Used three of them.
Bob
Sent from my iPad using Tapatalk HD
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
Greenville, GA
« Reply #14 on: May 30, 2013, 09:36:53 AM »
On the movie PT109 they used a real PT boat. The V12 Packard engines do resemble the Detroit 12V-71's alot. The PT boats used three. I believe the outer engines were normally mounted with the center facing backwards through a V-drive. With 1500hp each, they drank alot of high octane av gas. If they had been Diesel, the fuel consumption would have been half. Good luck, TomC
