April 22, 2018, 01:36:41 AM *
Author Topic: Front Hubs, removing oil.  (Read 2445 times)
wg4t50
« on: May 29, 2013, 05:15:25 PM »
Does anyone think they could remove over 1 1/2 quart of oil from the front hubs (2) using a turkey baster as a vaccum pump thru the small hole in the cover after removing the rubber plug ?   Grin Grin
I said no way, but was told I was wrong. Guess I must be from Mo. ? Show me.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Jon
« Reply #1 on: May 29, 2013, 05:29:29 PM »
I guess anything is possible, but how do you get the turkey baster past the nut and outer bearing?
Is there really that much oil in there? I don't recall ever putting that much in.
Jon
Knoxville, TN
Utahclaimjumper
« Reply #2 on: May 29, 2013, 05:49:43 PM »
 You had better check that amount again,, only about 1/2 quart in the average hub.>>>Dan If its a standard "Stemco" hub cover,, it will have a hex plug on one side for draining without removing it, just rotate the wheel to position the drain plug at the bottom and let it drain out into a pan)
« Last Edit: May 29, 2013, 05:52:16 PM by Utahclaimjumper » Logged
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #3 on: May 29, 2013, 06:39:30 PM »
Not many of Stemco hub caps have drain plugs now days just loosen the bolts and drain is the way I do it
 I have saw people use brake fluid bulbs or a mighty vac to change the oil so I would say a turkey baster would work I never saw a hub hold a quart and a half before
Utahclaimjumper
« Reply #4 on: May 29, 2013, 06:45:55 PM »
Drain plug type stemco's are available at most NAPA stores,, about eight bucks.>>>Dan (I would not have it any other way)
« Last Edit: May 29, 2013, 06:47:35 PM by Utahclaimjumper » Logged
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
Scott & Heather
MCI-9 & MCI-102
« Reply #5 on: May 29, 2013, 06:53:10 PM »
I just pulled the covers off and let it make a mess. The stuff stinks so bad. For weeks. Ugh.
Scott & Heather
« Reply #6 on: May 29, 2013, 06:57:30 PM »
Dan,all buses are not GM the ones for my Eagle were 22 bucks each at Napa and had no drain plug and were not cast either
Utahclaimjumper
« Reply #7 on: May 29, 2013, 06:57:56 PM »
 You won,t have that problem when using "LUCAS" hub oil.>>>Dan
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
Utahclaimjumper
« Reply #8 on: May 29, 2013, 06:59:46 PM »
 Cliff, if not cast aluminum, then what,,>>>Dan  (Last pair I bought was for my American Coach)
« Last Edit: May 29, 2013, 07:02:14 PM by Utahclaimjumper » Logged
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
« Reply #9 on: May 29, 2013, 07:10:25 PM »
They were metal I tried to find ones with a drain plug they didn't make one that would fit my hubs because of the bolt pattern I believe you can buy that type for a 10 I see very few now with drain plugs
chessie4905
« Reply #10 on: May 29, 2013, 07:18:32 PM »
just run them with the old seals....eventually they will leak out onto the brake lining and you can then remove the covers without a mess on your rims on the outside.Smiley
GMC h8h 649#028 (4905)
Pennsylvania-central
Utahclaimjumper
« Reply #11 on: May 29, 2013, 07:39:03 PM »
 Only two reasons I can think of for leakage,,(1) old and wore out,  (2) bearings adjusted too loosely and not running on center.>>>Dan
Utclmjmpr
Cedar City, Ut.
 72 VW Baja towed
wg4t50
« Reply #12 on: May 30, 2013, 12:14:26 AM »
I see we are on the same page here, I have been on another forum where there has been talk about how to change the hub oil, when this one showed up I could not contain myself, so had to post it here.
Seems the normal B.S. from the know-it-all types who are clueless but are word smiths, posting all types of useless info.
Thanks  for the comments, I now can sleep comfy knowing I have not lost my shrinking mind yet. Grin
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
