May 23, 2018, 10:08:36 AM *
Author Topic: MC-5A Ride height  (Read 2156 times)
FolkBus
It's a family thing
1967 MC-5A - 1949 Crown Supercoach
« on: June 19, 2013, 03:18:59 PM »
Hi all
My MC-5a has a list to starboard. What I'm not sure of is if the port side is too high (overinflated) or the starboard is low.  What is the correct height (ground to body floor)??  I don't want to start adjusting with out the correct information.
--Mike
Mike and Debbie McNeil  Ridgway - Montrose, CO
1949 Crown SuperCoach (Amazing Grace) Conversion 1972  Pancake 220 Cummins  Fuller 5 Speed
1967 MC-5A  (Serenity)  Conversion 1986  8v-71N   Allison MT-644
viento1
« Reply #1 on: June 19, 2013, 03:39:01 PM »
I will scan that page of the manual for you.
Ok, it's time to go on another road trip.
www.randalclark.com
MC5
FolkBus
It's a family thing
« Reply #2 on: June 19, 2013, 03:50:39 PM »
« Reply #3 on: June 19, 2013, 05:19:00 PM »
I do not have my book handy but aside from measuring the ride height from the ground, it may be better to measure it from the airbag inflation.  I forget the exact numbers but the front bags should be the same since they are on the same valve.  The rear bags, although on separate valves should also be the same-- say about 7 inches including the plates.  Get the rear bags even by adjusting the linkage to the valves.  If there is any play in the linkage, that should be fixed or replaced.  A turn buckle with some lock nuts will work fine.
codretaw1
1965 mci 5A south lyon, michigan
« Reply #4 on: June 19, 2013, 05:40:06 PM »
hi sounds like you have a bad leveling valve has one in front two in back
viento1
« Reply #5 on: June 20, 2013, 09:55:59 AM »
I scanned the entire section but the 2 diagrams showing how to measure ride hieght will probably serve you best. Consider that on an RV application the adjustable ride height may not be necessary.
I removed the adjustable height and put manual guages up front. I can set them to exactly the correct pressure to keep my coach measurements perfect. Slight adjustment for fuel that is probably not a big deal. The best part is that for all of you that are level freaks, you can adjust the air pressure from the Helm just like a fancy pants Prevost Marathon coach Smiley
To get the pdf, please send a PM and give me your email. Unless there is a resource section???
www.randalclark.com
MC5
FolkBus
It's a family thing
« Reply #6 on: June 21, 2013, 08:07:06 AM »
Thanks..My email is on profile
viento1
« Reply #7 on: June 24, 2013, 10:18:00 AM »
I sent it to you via email. If anyone else wants a copy please PM me.
www.randalclark.com
MC5
