June 19, 2018, 03:52:02 AM *
Author Topic: Up On The Roof  (Read 2419 times)
paul102a3
« on: June 26, 2013, 08:46:56 AM »
I need to get up on the roof of our 2000 Prevost XL II to check out a water leak coming from a roof top A/C unit.
Any suggestions as to where to stand or walk. I have been on the roof of our MCI many times and it was real easy to stay on the support ribs. Is it easy to to see the location of the ribs on a Prevost? Do I need to stay on the ribs or is the roof strong enough to support a 230 lb person?
Thanks in advance,
2001 Prevost XL II
muldoonman
1991 Prevost 8V92TA
1991 Prevost 8V92TA
« Reply #1 on: June 26, 2013, 09:57:48 AM »
Don't know Paul, but if I got up there i would just get me some narrow plywood and set it down to distribute weight. Move it around to where you need it. Home Depot will split it for you if you don't have a saw. Take a 4x8 sheet of 1/2 inch and split it for your needs.
Gordie Allen
« Reply #2 on: June 26, 2013, 01:42:06 PM »
When I get up on the roof, I wear snowshoes.   Grin
Augusta, MI
1956 4104
DD 671
« Reply #3 on: June 26, 2013, 01:48:13 PM »
The roof is structure on a Prevost at shops you see 2 or 3 people walking on one carrying a roof top
paul102a3
« Reply #4 on: June 26, 2013, 03:59:50 PM »
Thanks for the info on the roof strength. It will make a lot easier finding the cause of the leak if I can move around without worrying about damaging anything.
2001 Prevost XL II
« Reply #5 on: June 26, 2013, 04:03:28 PM »
Hi Paul,
An XLII will have ribs every 32" and the aluminum skinning is pretty strong..
So, if your not on the ribs, you will still be ok.
Stay safe!
Geom
1966 PD4107
« Reply #6 on: June 26, 2013, 05:01:58 PM »
Hi Paul,
Stay safe!
Hi Nick,
Since the GMs are a similar aluminum skin design, do you know if that would be true for them as well?
Thnx
1966 GM 4107
6v92 Turbo
V730
SPICEY MEATBALL
« Reply #7 on: June 26, 2013, 05:06:58 PM »
I get tickled every time I see 5 or more of them roof warts up there Grin
Ex 1989 Model 15 Predator class War Bird owner
« Reply #8 on: June 26, 2013, 06:23:52 PM »
Hi Nick,
Thnx
I have not built a racedeck on a GM yet but, we have built 14 decks so far on H3-45's and 2 on XLII's.
I ill let you know if e do.
« Reply #9 on: June 26, 2013, 06:29:36 PM »
Some of our decks.
XLII &
H3-45
« Last Edit: June 26, 2013, 06:31:36 PM by Nick Badame Refrig. Co. » Logged
muldoonman
1991 Prevost 8V92TA
1991 Prevost 8V92TA
« Reply #10 on: June 26, 2013, 06:38:40 PM »
Good NASCAR rig there Nick!
« Reply #11 on: June 26, 2013, 07:19:51 PM »
Thanks!
There are a lot of better pics on our FB page.
paul102a3
« Reply #12 on: June 26, 2013, 08:18:18 PM »
Nick,
Thanks for the info on rib spacing.
2001 Prevost XL II
