February 18, 2018, 10:27:52 PM *
Author Topic: Need Part for Old Kohler Generator  (Read 1940 times)
« on: June 27, 2013, 11:16:07 AM »
The vacuum choke diaphragm on my pre-Columbian L654 Kohler generator is bad.  This is not a huge deal since all it means is that the generator is slower to start in cool weather, or I have to jiggle the choke to start it faster.  However, it would be nice to fix it.  I have not been able to find the diaphragm or a repair kit.  Does anyone know of a source for such ancient parts?
« Reply #1 on: June 27, 2013, 07:57:55 PM »
I had the same problem with my ancient Onan and just choked it by hand until it warmed up.
Not convenient but the part is not available.
« Reply #2 on: June 27, 2013, 08:49:51 PM »
Yeah Gus, that's what I do when I need to.  Just thought it would be nice to fix it.  Can't understand why they don't have little parts for a merely 40 plus year old generator!
« Reply #3 on: June 27, 2013, 09:59:14 PM »
Lin, I have no idea where to get the parts but that has always been a simple fix go to a wrecking and  find a vacuum cylinder off the fresh air door from a automobile find the smallest size, a rod and bracket you are in business you could probably buy one from NAPA or AutoZone
 I watched a guy do that before on a Onan to do away with his electric choke also  it was simple the engine not running the choke was closed running it was open from the vacuum from the engine a old dash pod off a carburetor should work
« Last Edit: June 27, 2013, 10:07:10 PM by luvrbus » Logged
wg4t50
« Reply #4 on: June 28, 2013, 01:59:56 AM »
Years ago I had the Kohler using the flat head 4 cyl water cooled gasoline engine, no diaphragm assist choking, just carb ice under the right conditions, so being a fool, I changed it to LP Gas, had a 60 gal LP tank, worked great as such, my gph went from .75 to 1.1 gph, so I got real tired of that real quick, yes it was a perfectly nice easy, smooth, reliable setup, but LP refills are not cheap and the 60 gal tank gave limited range, so I built the 12 kw diesel, used a 50 gal tank.
I figured 10 gal per 24 hr run, I ran it 24/7, so the 50 gal gave me 4 full days run time.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Paso One
« Reply #5 on: June 28, 2013, 02:00:32 PM »
Okay guys have you tried  www.smokstak.com
Please don't hold me responsible for your extra 3 hours a day you spend on another website. Smiley
There is a company on there that has NOS parts for all old engines.
Carb kits for many old small engines, broken down by make and model.
1996 MCI 102 D3
« Reply #6 on: June 28, 2013, 02:28:28 PM »
Better would be an electric, short throw solenoid connected to a switch at the driver. Some of these old engines require a lot of choking.
