May 23, 2018, 07:41:19 AM *
Author Topic: Need Generator Guru  (Read 5333 times)
« Reply #15 on: June 29, 2013, 08:11:45 PM »
I would try Ring Power the Cat dealer in Orlando it doesn't have to be a Cat for them to work on it they worked on my Wrico rental stores like United always have good generator people some will do outside work some won't doesn't cost to ask
« Last Edit: June 29, 2013, 08:20:24 PM by luvrbus » Logged
Seangie
www.herdofturtles.org
« Reply #16 on: June 29, 2013, 08:25:02 PM »
Hey all -
Just some updates -  1st thanks for all the responses and suggestions.  All have been taken into account.  Gods got us in good hands as we are safely tucked away at a friends house.  We'd be fine at a campground, it just driving with no Air Conditioning that is challenging in this FL humiditiy.
Dave M -  I hope I get some time to dig deeper into the issues.  Thank you for the suggestions.  If I get time,  I will try to play with it some more.  So far I have tested for voltage on the lines right in front of the breaker and I get nothing at all.  I have not had time to dig into it too much.  Possibly tomorrow afternoon I may have a go at it.  Currently we do not have an auto transfer switch.  Electrical was the last on the list of things to get done and hoping to do that soon.
Bob -  you are correct in that the air conditioner works and the genny starts up, we just don't have any voltage from the generator.
Thanks for the numbers and leads.  I am following up with them all.  I didn't think it would be so hard to get someone to do the work.  We called half a dozen places Thursday and Friday and have had no calls back and others that flat out won't service generators that are not brand specific.  I think we need an old timer with experience thats not afraid of doing some work. A new install is not out of the question either.
Scott -  thanks to you and Heather for the prayers.  Gods doing amazing things here.
John - Got your PM.  Thanks for the information.
Ill keep you all posted as to what we find out.
Thanks again.  Keep the suggestions coming.
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
wg4t50
« Reply #17 on: June 30, 2013, 02:38:51 AM »
Just a quick thought, IF you have NO voltage at the switch, maybe you have a trippedbreaker near the generator.  You should have at least a residual voltage of 5-20 Volts AC, IF you do not have that, your into a bigger $$$$ isue, why I would be looking for a breaker tripped and hoping.
Just a thought as in been there & done that
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Seangie
« Reply #18 on: June 30, 2013, 05:39:52 AM »
Dave,
The breaker that I tested in front of was the one on the generator. I checked the voltage from each leg that comes from the generator head into the breaker box on the side of the generator.  I checked each leg to neutral and across both legs.  Nothing anywhere.  I'm expecting a worst case scenario of having to rebuild or replace the genny head.
Thanks again.
'Cause you know we,
wg4t50
« Reply #19 on: June 30, 2013, 06:15:52 AM »
ZERO voltage is BAD news as in $$$$, if the 5-20 volts, not a big $$$$ thing.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
niles500
Niles500
ROSIE
« Reply #20 on: June 30, 2013, 09:58:48 PM »
I'm more interested in what Paul at Martin had to say - those Martin's are bulletproof - I'm still sure it's a breaker - or post head electrical problem - FWIW
(\__/)
(")_(")
- Niles
wg4t50
« Reply #21 on: July 01, 2013, 07:28:12 AM »
Along with bullet proof, you get to idiot proof, fool proof.   Grin
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Seangie
« Reply #22 on: July 03, 2013, 09:38:23 AM »
Got the generator fixed -
Back Up Power Services, Inc.
1911 N. Orange Blossom Trail
Orlando, FL 32804
http://orlandogenerator.com
It was a bad capacitor that needed to be replaced.  Good shop.  They were quick and to the point.
Thanks all for help & Suggestions.
'Cause you know we,
« Reply #23 on: July 03, 2013, 10:10:03 AM »
Great news....prayers answers once again !!
Donald PH
wg4t50
« Reply #24 on: July 03, 2013, 11:40:59 AM »
Hope you bought a spare capacitor and watched how to install, the day will come again.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
OneLapper
« Reply #25 on: July 03, 2013, 11:44:47 AM »
Simple and fast!   Fantastic!
OneLapper
1964 PD4106-2853
www.markdavia.com
Oonrahnjay
« Reply #26 on: July 04, 2013, 08:01:09 AM »
  Got the generator fixed -   It was a bad capacitor that needed to be replaced.
     Where was the capacitor?  Actually in the generator head or control system, or outside of the generator?   Thanks,  BH    NC    USA
Seangie
« Reply #27 on: July 05, 2013, 04:23:11 PM »
Bruce,
If you look at one of the first pics I posted you can see both caps sitting on the top of the left side of the genny above the electrical box.
'Cause you know we,
