February 17, 2018, 11:51:38 AM *
Author Topic: Slide outs?  (Read 3624 times)
« on: July 03, 2013, 05:01:29 AM »
If you have been thinking of doing your own slide outs, here is an item you might be interested in.  http://happijac.com/index.php/products/slide-outs.
 Happy Bussin Smiley
« Reply #1 on: July 03, 2013, 05:21:36 AM »
It looks like a convenient ready-made unit, but that type of mechanism only works in situations where some piece of furniture (and it basically only applies to a bed) will continue to occupy floor space in front of the slide-out, even when the slide is fully extended. But if that's the kind of slide-out you're building, it might be just the job
Tikvah
« Reply #2 on: July 03, 2013, 05:31:33 AM »
I'm getting a dead page ?
1989 MCI-102 A3
DD 6V92 Turbo, Alison
Tons of stuff to learn!
http://dave-amy.com/
arutkow
« Reply #3 on: July 03, 2013, 05:40:06 AM »
There was a "." at the end of the original link.
Jon
« Reply #4 on: July 03, 2013, 05:47:53 AM »
What is not recognized is making a slide out is much more complex than just cutting a hole in the sidewall and rolling out a small room.
On some coaches the hole in the side goes through a required structural assembly such as on a Prevost.
Then there is the issue of sealing the opening. And the problems associated with flexing and binding. I don't doubt an owner with a good understanding of engineering principles could successfully add slides to any coach, but it took Prevost quite a few years and 4 or five redesigns before they finally got it right. Call me a cynic.
Jon
Knoxville, TN
muldoonman
1991 Prevost 8V92TA
« Reply #5 on: July 03, 2013, 06:59:47 AM »
 Everybody knows all you need to install one of these is a 100 amp wire machine, a 12 ounce hammer and a 12 inch cresent wrench. Do it in an afternoon. Don't forget the beer. (This said tongue in cheek)
« Reply #6 on: July 03, 2013, 07:17:41 AM »
Absolutely - those two issues trump all others by far - but when you're installing a slide-out the only question anyone ever asks is "will it be electric or hydraulic?"
« Reply #7 on: July 03, 2013, 09:27:45 AM »
With my custom made 32ft box for my truck conversion, I was considering getting 2 slide outs made until I got a quote for $20,000 each. As it turns out, don't need them anyway. I like simplicity. Good luck, TomC
Dave5Cs
« Reply #8 on: July 03, 2013, 10:27:40 AM »
Oh come on now. Just a piece of 1\2 ply for a floor. Build 3 walls out of 2x2s cover with shingles and a piece of sheet metal for the top done your welcome. If it was for the bathroom pop out you wouldn't even need a holding tank under it. Just roll it on out.
Dave5Cs from Galaxy S III
« Last Edit: July 03, 2013, 02:55:11 PM by Dave5Cs » Logged
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
Scott & Heather
MCI-9 & MCI-102
« Reply #9 on: July 03, 2013, 11:04:20 AM »
Oh come on now. Just a piece of 1\2 ply for a floor. Build 3 walls out of 2x2s cover with shingles and a piece of sheet metal for the top done your welcome. If it was for the bathroom pop out you woyldn t even need a holding tank under it. Just roll it on out.
LOL Smiley
Scott & Heather
Emcemv
1973 MCI MC-7 Combo
« Reply #10 on: July 03, 2013, 02:21:46 PM »
Isn't it great to see some humor on this board!!!
Bruce & Nancy Fagley
1973 MCI MC-7 Combo Freighter
450HP DD 8V-92T 2000 Reman
HT 740 Allison
Woodbury CT.
Dave5Cs
« Reply #11 on: July 03, 2013, 03:03:32 PM »
Just though we all needed a little lightheartedness after these last 2 weeks. Must have been the heat.  Grin
 110 degrees here today in Sacramento-Roseville area, but its a dry heat!... Today our chickens are laying eggs and they are so hot when you crack them open a flame shot out!... Shocked
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
