April 22, 2018, 09:40:01 AM *
Author Topic: 240 volt roof air  (Read 4857 times)
Scott & Heather
MCI-9 & MCI-102
« on: July 03, 2013, 09:11:45 PM »
Would a 240 volt roof air 13,500 btu be able to run on a 1500 watt 240 volt generator?
Sent from iPhone via Tapatalk
Scott & Heather
« Reply #1 on: July 03, 2013, 09:55:56 PM »
Doesn't matter what voltage the unit is, it's the starting wattage and running wattage that makes the work. Typically, if an air conditioner needs 1500 watts to run, it would need double that wattage to start it-especially when it's hot. Good Luck, TomC
wg4t50
« Reply #2 on: July 04, 2013, 04:37:37 AM »
1500 watts at any voltage will not work for the a/c roof unit, it would take an older Onan 2500 watt to have a chance, Generac and other econ wannabee gensets would require about 5000 watts.
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #3 on: July 04, 2013, 06:12:50 AM »
I'm curious where you found a 240 volt roof top A/C unit?  Is it European?
Scott & Heather
MCI-9 & MCI-102
« Reply #4 on: July 04, 2013, 06:51:41 AM »
Yes, I don't own one, but yes, european model. Basically wanted to know if the higher voltage would allow for less watts needed...i'm an electricity dummy.
Scott & Heather
azdieselman
« Reply #5 on: July 04, 2013, 08:14:17 AM »
Amp X Volts = Watts. You are 1/2 right, The higher voltage will draw less Amps, Not Watts.
1980 Mod 10
« Reply #6 on: July 04, 2013, 08:18:38 AM »
 Grin
« Last Edit: July 04, 2013, 08:47:31 AM by robertglines1 » Logged
technomadia
Zephyr - 1961 GM PD-4106-446
« Reply #7 on: July 04, 2013, 09:27:26 AM »
This is absolutely true - the starting surge usually requires an over-size generator to get the roof unit running. Double the wattage is probably a safe rule of thumb.
You can mitigate this somewhat with a "soft start" kit for the the roof AC that uses a larger capacitor to bring down the starting surge current requirements.
Or an even better way is to use an inverter that can supplement your generator power with battery power for the duration of the starting surge. This way you can size your generator for the average running load, not the peak surge load.
Cheers,
  - Chris
« Reply #8 on: July 04, 2013, 10:04:54 AM »
Some of the new portable inverter generators could start a roof air. I would still go with no smaller then 2000 watts with closer to 3000 watts better.
It doesn't matter whether it's 120vac @ 12.5 amps or 1500vac @ 1 amp, it's still 1500 watts and you need a 1500 watt generator to create it. Good Luck, TomC
« Reply #9 on: July 04, 2013, 10:28:46 AM »
You must also be aware of the frequency.  Many European models will be 50Hz.
pvcces
« Reply #10 on: July 04, 2013, 06:22:03 PM »
That 50 hz air conditioner might take 1800 watts if it was run on a 60 hz generator because the compressor would likely run 20% faster than normal.
It's something to consider.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
HB of CJ
« Reply #11 on: July 04, 2013, 07:43:21 PM »
A/C starting with other running loads running may prevent it from even starting--even if the gen set is way larger than you think you need.  Relays needed?  Also the environment comes into play.  If you are very hot outside and at very high altitude, good luck with that marginal gen set...it just might not work at all.  Like already answered better; sometimes a 50 Htz A/C unit and a 60 Htz genset may not mix.  Faster; (with all potential concerns) and hotter?  HB of CJ (old coot)
« Reply #12 on: July 04, 2013, 08:04:09 PM »
A 1,500 watt 240 volt generator would be pretty small for 240 volt.  Most with 240 volt are 3000 watts and up.
Scott & Heather
MCI-9 & MCI-102
« Reply #13 on: July 05, 2013, 05:19:27 AM »
Ok, so my 3000 watt generator isn't producing more watts in 240 volt mode?
Scott & Heather
« Reply #14 on: July 05, 2013, 05:34:48 AM »
Watts are watts no matter what voltage.  Amps will change as voltage changes.  Your generator produces the same amount of power no matter if 240 volt or 120 volt.
You don't use any less power by going with a 240 volt rooftop.  You're better off with 120 volt for ease of replacement and repair.  You also won't have to deal with 50 hz versus 60 hz.
