February 25, 2017, 03:58:08 AM *
Author Topic: A Timing  (Read 1385 times)
Rick 74 MC-8
« on: July 08, 2013, 08:02:10 AM »
I remember reading but I don't know if there was a definitive answer. Is there an easey way to check to see if a 8v71 is A timed. My engine I believe is A timed with  n65 Brown tag injectors. I can make it smoke at will at almost any rpm. The rack was run about a year ago
 Thanks Rick
« Reply #1 on: July 08, 2013, 08:33:36 AM »
A timing was never intended to be used with a 4 speed that was a truck setup for 10 speeds works well there
Utahclaimjumper
« Reply #2 on: July 08, 2013, 09:10:02 AM »
 "A" timing works well by cranking up the governor to 2400-2450, keep it spinning to minimize smoke and maximize pulling power.>>>D (RPM will also keep the fan speed up to control heat build up)
« Last Edit: July 08, 2013, 09:19:58 AM by Utahclaimjumper » Logged
Utahclaimjumper
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Rick 74 MC-8
« Reply #3 on: July 08, 2013, 11:01:33 AM »
I'm happy with the performance. Im not sure if it is A timed. Was wondering if there is a easy way to check.
Rick
« Reply #4 on: July 08, 2013, 12:34:53 PM »
The book shows a method wherein you pull an injector and measure the cam lift at TDC or something similar.  It sounds like a pita, involves a dial indicator with a very long probe.  If you are really interested I can copy it to you.  If your injectors are timed at 1.484 it is probably A timed, if it is timed at 1.460 it is probably S timed.
« Reply #5 on: July 08, 2013, 03:49:58 PM »
incase you wish to know....7E65 injectors have built in Adv, C/S Timing.... Grin
Donald PH
Wants Paint Smiley
