June 20, 2018, 04:52:59 AM *
Author Topic: A very bad Monday.  (Read 5981 times)
thomasinnv
Derrick Thomas
« Reply #15 on: July 10, 2013, 10:13:53 AM »
You should consider a short flexible hose on both sides of the pump. With all the road vibration its a good idea not to mention if you have the noisy pipes when the pump runs it helps considerably.
Sent from my PantechP9070 using Tapatalk 2
1998 MCI 102-DL3
Series 60 11.1/Alison B500
trucktramp
« Reply #16 on: July 10, 2013, 07:52:49 PM »
Hey it's probably good you stepped on the nail.  If you had driven over it you would have had a flat tire to fix which would likely be a road service call...maybe a new tire.  The tetanus shot was probably cheaper.
Dennis Watson
KB8KNP
Scotts, Michigan
1966 MCI MC5A
8V71
Spicer 4 Speed Manual
Scott & Heather
MCI-9 & MCI-102
« Reply #17 on: July 11, 2013, 05:25:09 AM »
Definitely going to put flexible hose on either side of pump now...good idea.
And yes, the nail in the foot was less painful than the nail in the tire would have been  Grin
Scott & Heather
Scott & Heather
MCI-9 & MCI-102
« Reply #18 on: July 11, 2013, 05:26:08 AM »
Sean,
Looking very much forward to seeing you guys!
Scott & Heather
pabusnut
« Reply #19 on: July 11, 2013, 05:53:06 AM »
Scott,
If you ever watched "Hee Haw" on TV, you've probably heard my themesong---"if it wern't for bad luck...."
I empathize with your plight!
Thanks for the story!
Steve Toomey
PAbusnut
Steve Toomey
PAbusnut
pipopak
I am the 99%
« Reply #20 on: July 12, 2013, 09:12:11 AM »
"When several things can go wrong, they will in the order that will cause the maximum amount of inconvenience"
Murphy.
Linux, when Windoze just will not measure up.
