April 24, 2018, 06:11:13 PM *
Author Topic: tires, batteries and now sewer lines  (Read 6090 times)
lvmci
« on: July 13, 2013, 09:30:11 PM »
Hi All, driving from san bernadino to van nuys ca. to get nearer to work, on the I-210 fwy, an 18 wheeler which just pulled in front of me, blew at least two of the right back tires, at 70mph I could hear it in the bus with radio and air going, I saw the whole occurance shrapnel, pieces flying, and an entire carcass of one tire, in one piece, flying at me, fortunately went under bus, felt it hit the tires, and saw the jeep jump twice in the rear camera. Of course all of this in just seconds. I pulled over as soon as safe, and saw a big ruccuss behind me. jeep looked ok and didnt hear or see anything on the bus. When I arrived at the RV park, no brakes on the jeep, $1200 later jeep is repaired, I began to look closer at the MCI, saw some dripping underneath, upon very close inspection I discovered the black water sleeve and valve unit had been snapped off and was holding by a thin piece of glue. When I went to inspect it closer, it came right off, and the hole is rough on the plastic, holding tank. Has anyone repaired the drain hole, are they fixable? the female receptical seemed to have been glued on to the tank, and the 3" black hard sewer line to the valve that screwed into it are all glued together, I'll take a pic tommorrow, I put an Oakey temporary plug in the hole, thanks, lvmci...
MCI 102C3 8V92, Allison HT740
Scott & Heather
MCI-9 & MCI-102
« Reply #1 on: July 14, 2013, 05:06:02 AM »
Sorry to hear about this. Expensive accident. Wish the trucking company could pay for it. Anyway, are you absolutely sure the female fitting is glued into the tank? It might be spun weld but usually a threaded fitting is spun weld into the tank and you can unthread your pipe from that. Unless you're saying the fitting is broken which is annoying cause that will be harder to fix. Any pics?
Sent from iPhone via Tapatalk
Scott & Heather
lvmci
« Reply #2 on: July 14, 2013, 06:26:59 AM »
Here's a pick of the outlet, 3 3/4" hole, 4 1/2" imprint of the threaded female piece that broke off, tom, lvmci...
lvmci
« Reply #3 on: July 14, 2013, 06:31:03 AM »
here's the inlet, a duplicate of the outlet from the top of the tank, a wider view and a pick of the oakley stopper, from hd, to plug the hotel, lvmci...
lvmci
« Reply #4 on: July 14, 2013, 07:07:18 AM »
The bus's original conversion was done in 1986 by Designer Coach of Salmon Arm BC Canada, out of business now, a remarkable job, to last 27 years, lvmci...
SPICEY MEATBALL
« Reply #5 on: July 14, 2013, 07:10:19 AM »
Tom, I rotated the picture for ya  Wink
Ex 1989 Model 15 Predator class War Bird owner
chessie4905
« Reply #6 on: July 14, 2013, 07:59:34 AM »
  Sorry about your luck, that sucks..I hope the tank was mostly empty at the time, as, even though it wasn't your fault and if the tank was full, Calif. would have declared the spill as a major environmental disaster with mega fines. How about a threaded flanged outlet, inserted from top of tank and installing nut and gasket to seal and go from there? (after cleaning up and smoothing surface of bottom side of tank so gasket will seal properly). If outlet is too close to corner, is it practical to shift tank out a little for clearance?
GMC h8h 649#028 (4905)
Pennsylvania-central
« Reply #7 on: July 14, 2013, 08:09:11 AM »
Buy the plastic welder from H/F for 50 bucks with the correct rod material for the type plastic and weld the sucker it's a fairly good little welder for the money the 14 dollar one is junk
lvmci
« Reply #8 on: July 14, 2013, 08:13:40 AM »
Hi Chessie, good suggestion, I wil pursue that idea, here's my idea to fully empty the black tank before leaving the park, the lip of the flexible coupler may be enough to seal the drain hole to wash out the tank,  lvmci...
lvmci
« Reply #9 on: July 14, 2013, 08:21:13 AM »
Hi Cliff, plastic welder, good idea, I've always welded plastic with a a butter knife heated on the stove, I guess that won't work here, tom, lvmci...
lvmci
« Reply #10 on: July 14, 2013, 09:55:09 AM »
Hi All, a successful black tank drain, with temporary 3" coupler, very little seepage while draining, thanks to Tom C also for the recommendation as to a shop, lvmci...
Scott & Heather
MCI-9 & MCI-102
« Reply #11 on: July 14, 2013, 07:50:39 PM »
I can't see your Pics...but cliff was
Right on as always. I welded my
Tank with the harbor freight welder.
Works like a charm
Scott & Heather
« Reply #12 on: July 14, 2013, 07:55:56 PM »
After seeing the pictures-it looks like you could have a new fitting spin welded back into place. I would suggest you call at Ronco-plastics in Irvine and send those pictures to see if they are willing to spin weld a new fitting in. The web site is www.ronco-plastics.com  Good Luck, TomC
« Reply #13 on: July 14, 2013, 08:04:10 PM »
Spin,fusion and rod welding are about the same with plastics it's all done with heat spin welding is heat caused by the spinning of the fitting then if fuses together I doubt a spin weld would hold on a tank that old the chemical make up has changed over the years
« Last Edit: July 14, 2013, 08:08:07 PM by luvrbus » Logged
lvmci
« Reply #14 on: July 15, 2013, 07:08:39 AM »
Hi All, thanks to Cliff and Tom and all others who have advised, Friday done with this job and will update as to what I'm able to accomplish, tom, lvmci...
