August 20, 2017, 04:53:41 AM *
Author Topic: Item needed  (Read 2500 times)
tuccitown
« on: July 18, 2013, 03:36:14 PM »
Anybody know where I can get the intake hose for my coach (see attached) locally to Seattle? Does anyone have a part number? This is the intake hose from silencer to oil bathed air cleaner.
Thanks in advance,
Jack
1979 GMC H8H649-053 Conversion in progress.
1955 GM PD 4501-377 Converted.
« Reply #1 on: July 18, 2013, 04:04:03 PM »
That is called hump hose just measure the ID and length you probably have to order it that one looks like 7 in id Napa if you get the right parts guy can have it overnight fwiw 1 hump will work for you just as good as the 4 you have
« Last Edit: July 18, 2013, 04:09:38 PM by luvrbus » Logged
Scott & Heather
MCI-9 & MCI-102
« Reply #2 on: July 18, 2013, 04:24:18 PM »
Hey Cliff, you sure it's called a hump hose? Maybe you made that up just like slobber tube Smiley Wink
Sent from iPhone via Tapatalk
Scott & Heather
« Reply #3 on: July 18, 2013, 04:30:34 PM »
nope didn't make it up www.intakehoses.com and others
Gordie Allen
« Reply #4 on: July 19, 2013, 04:46:28 PM »
Check out http://www.hps-siliconehoses.com/?gclid=CKv8yOfhvLgCFa1FMgod3yoA3g
Augusta, MI
1956 4104
DD 671
« Reply #5 on: July 19, 2013, 04:54:10 PM »
Only bad thing about silicone hump hose the least bit of oil will destroy it, the stuff is expensive and not compatible with oil found that out the hard way
Gordie Allen
« Reply #6 on: July 19, 2013, 04:57:19 PM »
True.  Didn't think about outside contamination, or oil bath fumes.
Augusta, MI
1956 4104
DD 671
tuccitown
« Reply #7 on: July 23, 2013, 11:07:33 AM »
Thanks, I ended up ordering one of these as Napa was not much help.
http://intakehoses.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=55H55&Category_Code=HH1
Didn't realize they were in Washington so hopefully I'll get it pretty quickly.
Thanks again.
Jack
