May 22, 2018, 02:26:01 PM *
Author Topic: Mci 7 air cleaner  (Read 1593 times)
junkman42
« on: August 01, 2013, 02:55:47 PM »
Does anyone know the Donaldson part number for the vacuator valves on the bottom of the four air cleaner canisters?  Any help would be appreciated!  Regards John L
ol713
« Reply #1 on: August 01, 2013, 03:15:04 PM »
  Hi;
     What is a "vacuator valve"? The air cleaners on my MC-7
     still has the oil bath type air cleaner. It is a 70'.  What
     year is yours?  Have you looked in the manual? Sounds
     like something has been changed. If you do not have a
     manual, I can have a lood tomarrow.
                                      Merle.
Dlsnow
dave
dave
« Reply #2 on: August 01, 2013, 03:43:08 PM »
My manual shows the following
9c-3-115 / valve-evacuator (rubber)
1972 MCI7 8v71 converted - 1kw solar on roof
« Reply #3 on: August 01, 2013, 03:52:52 PM »
 I would bet that that is the same for my 5A.  Will have to look and see if i can find it in my manual......i think i might be missing a page or two here and there.
« Reply #4 on: August 01, 2013, 04:03:39 PM »
Measure the size Napa can order those from Donaldson probably a lot of other places can too
junkman42
« Reply #5 on: August 01, 2013, 04:20:42 PM »
Dave, I have that part number but cannot cross it!  On the Donaldson website They refer to it as a vacuator valve.  No e for whatever reason.  The filter housing number is FWG080073.  I bought some of these a long time ago and do not have the info anymore.  Thought somebody might have the part number.  I will call Donaldson tomorrow and see what help They offer.  Will  post the numbers if I get them might save others the trouble.  Need four of them to replace them all.  John L
« Reply #6 on: August 01, 2013, 07:54:38 PM »
Dave i don't see that in my book. What page is it in yours? under what heading?
junkman42
« Reply #7 on: August 02, 2013, 06:55:16 AM »
Merle, sorry I did not acknowledge Your comment.  My coach is a 1972 and has four vertical canisters on the left side that take paper cyclonic filters.  I assume it came that way as the manual shows the assy but only MCI numbers!  The parts are no longer available from MCI.  Filter elements are readily available from many vendors.  Thanks for responding. John L
junkman42
« Reply #8 on: August 02, 2013, 08:26:14 AM »
Why the term Vacuator Valve?  According to the Donaldson person I talked too when under vacuum caused by filter restriction valve is pulled closed.  When engine is off valve opens and allows water and dirt  to drain.  Part number is P103198 and costs eight bucks the only problem is My local cat dealer which is Donaldson dealer has to order a minimum of ten valves.  Found on line at ebay from comepletecoach for 4 bucks each.  Even a blind squirrel finds a nut sometimes.  Thanks all for help  John L
