April 21, 2018, 08:59:48 AM *
Pages: [1] 2 3 4   Go Down
Author Topic: Help with GM 4104  (Read 14401 times)
harleyman_1000
« on: August 08, 2013, 11:09:56 AM »
 Ok I finally bought my first bus. It is a GM 4104. I am currently broke down and in desperate need of some information. I need to know where the fuse boxes are? I found 1 small fuse box inside the panel to the left of the driver seat, but it only has 5 or 6 fuses in it, so Im sure there is another fuse box somewhere? I called the guy I bought it from and he didn't know where it was? I don't have any tail lights, brake lights, or rear marker lights, but the turn signals do work, so Im guessing it is a fuse?  If you can help please call me since my internet doesn't work well here.  Scott 573-705-011 four
Scott
St.Louis Missouri
bansil
« Reply #1 on: August 08, 2013, 11:47:59 AM »
TRYING TO HELP UNTIL OTHERS RESPOND
http://www.busconversions.com/bbs/index.php?topic=19551.0
according to this post there are no fuses, just circuit breakers, there is a box in the back (by engine?) that can corrode and have loose connections
Doug
Mnt City TN
 Member of:
bansil
« Reply #2 on: August 08, 2013, 11:52:31 AM »
wire diagram here, downloadable
http://www.busconversions.com/bbs/index.php?topic=11159.0
Doug
Mnt City TN
 Member of:
« Reply #3 on: August 08, 2013, 12:53:16 PM »
A wiring diagram may not do him much good on that bus just find the junction box of breaker one will feed that circuit from a relay some place
chessie4905
« Reply #4 on: August 08, 2013, 04:43:30 PM »
closely check wiring and grounds at tailgate and harness going to it at top of engine compartment. You need to get yourself a test light from an auto parts store and probe connections there.
GMC h8h 649#028 (4905)
Pennsylvania-central
Seangie
www.herdofturtles.org
« Reply #5 on: August 11, 2013, 12:29:57 PM »
Scott -  did you get back on the road?
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
« Reply #6 on: August 11, 2013, 01:54:15 PM »
Scott has been real quite about his new purchase could be he is having the U Haul experience "Adventures in Moving" I hope he makes it ok
« Last Edit: August 11, 2013, 01:58:44 PM by luvrbus » Logged
Scott Crosby
« Reply #7 on: August 11, 2013, 03:08:59 PM »
Thinking out loud - Day and night mode on master?  Possibly someone did some rewiring and grabbed power from circuits only energized at night mode instead of day???
61 GM Fishbowl TDH 4516 102" 35'
1947 GM PD 3751
www.busgreasemonkey.com
Geoff
« Reply #8 on: August 11, 2013, 05:52:16 PM »
Scott (Harleyman 1000) just left my shop and is headed to Flagstaff 5pm Sunday.  I got his engine running correctly and then spent several days helping him straighten out the wiring.
He says he is going to stop at an Eagle Rally on his way back to St. Louis.
--Geoff
Geoff
'82 RTS AZ
uncle ned
« Reply #9 on: August 11, 2013, 06:15:59 PM »
Thanks geoff.  talked to him several days ago.
He was having a tough time for a new bus owner. always good to find a busnut to help.
How did the t drive in a 04 look. I saw the coach at Daytona bike rally quite a few years ago but could not find any one to talk to or let me get a good look.
uncle ned
4104's forever
6v92 v730
Huggy Bear
« Reply #10 on: August 11, 2013, 06:37:36 PM »
Since he will be on I 40 I will keep a eye out for him in case he has problems on my way to the Eagles rally,I think Scott has my cell number
harleyman_1000
« Reply #11 on: August 12, 2013, 12:29:24 AM »
Hey guys, Im almost at Flagstaff, and it's 2:38 am. I was blowing alot of black smoke all the way here, and head lights kept going on and off( made driving thru the mountains in the dark very interesting). Im parked at a  camping world and there is a Harley dealer next door. Im thinking I might have found the right spot to park for the night  Grin  Hey Clifford, I lost all my numbers when my old phone died, so please call me   573-705-0114
  Scott
Scott
St.Louis Missouri
saddleup
« Reply #12 on: August 12, 2013, 02:13:13 AM »
Clifford, you better bring that old jeep towbar i left at your place,on your way to Kansas you might need it....alot...lol
Yuma,Az
Scott Crosby
« Reply #13 on: August 12, 2013, 03:49:48 AM »
I assume somone has told you to not use the fuel pedal so much to control the smoke.  At that altitude you loose about 20% of your engine performance so be extra soft on the fuel petal.  It will be a dog with or without the black smoke so save some money on the black Unburnt fuel.  My lights used to dim severely everytime my factory ac/heater blower motors would kick in. They pull lots of 12v juice.  Is that system cycling on and off causing a problem or short?
1947 GM PD 3751
Seangie
« Reply #14 on: August 12, 2013, 04:20:48 AM »
Scott,
Glad you are still rolling!  Keep us in the loop.  The first days are the hardest days Smiley
'Cause you know we,
Pages: [1] 2 3 4   Go Up
