February 25, 2018, 02:08:19 AM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Help with GM 4104  (Read 13742 times)
tekebird
« Reply #15 on: August 12, 2013, 10:35:10 AM »
all of the electrical stuff is located in the left hand driver panel or the compartment just aft of the Curb Side Drive Wheel.  and a few odds and ends in the engine compartment
harleyman_1000
« Reply #16 on: August 12, 2013, 10:47:35 AM »
I assume somone has told you to not use the fuel pedal so much to control the smoke.  At that altitude you loose about 20% of your engine performance so be extra soft on the fuel petal.  It will be a dog with or without the black smoke so save some money on the black Unburnt fuel.  My lights used to dim severely everytime my factory ac/heater blower motors would kick in. They pull lots of 12v juice.  Is that system cycling on and off causing a problem or short?
 Im not using the factory heating or cooling, and there going totally off for like 30 seconds then coming back on. Other times they just flicker on and off like a loose wire, but since it works more often than it doesn't Im thinking it isn't a loose wire?
Scott
St.Louis Missouri
harleyman_1000
« Reply #17 on: August 12, 2013, 10:57:27 AM »
Clifford, you better bring that old jeep towbar i left at your place,on your way to Kansas you might need it....alot...lol
Are you going to tow my bus back to St.Louis, so I can use the saved gas money to buy the new wiper motor, inverter, refrigerator, and satellite system I need for the bus?   Sad
Scott
St.Louis Missouri
« Reply #18 on: August 12, 2013, 11:10:16 AM »
The headlight factory wiring is very simple, no relays or fuses involved.  You can get a wiring diagram here:  http://manuals.lenstudio.com/GM_PD4104MaintX-5818.pdf
In the meantime, here is the circuit (assuming previous owners haven't screwed it all up)
In the drivers panel from Breaker 11 to term 21 to the headlamp switch.  From there back to term 62 or 82, can't read it.  From there to the head lamp/fog lamp switch and from there to the dimmer switch and on to the headlights.
So, does it do the same thing on high or low beam?  The problem is before the dimmer, if not, it is after the dimmer.  The dimmer switch itself is a likely suspect, it is a pretty harsh environment in the tool compartment.
Good luck.
Miss Scarlett
« Reply #19 on: August 12, 2013, 05:00:55 PM »
My dimmer switch will cause the lights to go completely out if I hit it at the wrong angle. They have always come back on when I hit it the second time. It's been a long time since I have done a night trip. This reminded me to order a new one!
Miss Scarlett is an Eagle 10 with a 6v92 and Allison 740
UPDATE: finished enough to use!!!- exterior will remain original.
-Dan
« Reply #20 on: August 14, 2013, 08:43:17 PM »
Those dimmer foot switches are very prone to rust, especially when not used for a while.
harleyman_1000
« Reply #21 on: August 19, 2013, 03:11:34 PM »
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-prn2/9306_10201824856208825_1637252945_n.jpg
That is a link to my bus. I made it home. I replaced the fuse box and the lights never went out again.
Scott
St.Louis Missouri
harleyman_1000
« Reply #22 on: August 19, 2013, 03:13:46 PM »
 I was trying to stop at the Rally in Kansas and see some busnuts, but got stranded in Co with dead starter batteries and missed you all
Scott
St.Louis Missouri
Ralph7
« Reply #23 on: August 19, 2013, 03:37:30 PM »
      the bus looks great!!!!!!!!!!!!
« Reply #24 on: August 19, 2013, 03:43:39 PM »
Nice looking coach  Grin
Donald PH
harleyman_1000
« Reply #25 on: August 19, 2013, 03:45:15 PM »
Thanks, she looks much better in that picture, than in real like. She is all ready a love hate relationship
Scott
St.Louis Missouri
Miss Scarlett
« Reply #26 on: August 19, 2013, 06:09:56 PM »
No wonder that you bought that bus...she is sharp!
-Dan
treeplanter
the grey ghost,1971 GMC 5305A
« Reply #27 on: August 19, 2013, 09:04:53 PM »
Scott i thought i had problems bringing my bus home,it only broke down once,glad you got home safe.
Timothy
Sam 4106
« Reply #28 on: August 20, 2013, 06:26:59 AM »
Having a pretty bus, as Scott's is, is great, But having dependable, fully functional house systems, and a mechanically sound bus is much higher on my list of importance. With our old buses it takes a while to get them into that condition and constant maintenance to keep them there. I know I enjoy working on our bus to keep it in good condition, and have most of the skills to do so, but not everyone does. Those who don't enjoy working on their buses or have the skills, will need to find a reliable person(s) to keep them up, and be willing and able to pay for their services.
Good luck, Sam
« Reply #29 on: August 20, 2013, 09:04:49 AM »
so the honeymoon is over....what seems to be the first thing on the wish list.
ps anyone who has A Harley ought to be pretty able to make it work... Grin
Donald PH
Pages: 1 [2] 3 4   Go Up
