January 17, 2018, 06:45:46 AM *
Author Topic: I bought the 6V92  (Read 5384 times)
chuckd
« on: August 23, 2013, 10:39:42 AM »
Decided what the heck and bought the silver 6V92 from the Gillig bus.
In a couple of weeks will post some pics, but a two part question
The engine is a DDEC controlled engine.  Interstate diesel here in town, has converted a lot of these to mechanical engines, sooooo - do I take out the wiring harness and convert to a DDEC (I do not know the generation of DDEC) or go back to a mechanical engine?
Chuckd
1979 Prevost
« Reply #1 on: August 23, 2013, 10:49:41 AM »
Find out what generation it is the IV and III are not bad on a 2 stroke if a 1 or 2 convert it if it's the late run of a DDEC II the cams needs to be changed it can get costly
I still think you are selling the green engine a little short while the silver is a better engine tons of the green engine are still on the road with their fresh coat of silver paint
« Last Edit: August 23, 2013, 11:01:03 AM by luvrbus » Logged
chuckd
« Reply #2 on: August 23, 2013, 11:24:10 AM »
It should be a II, but not sure.  I am probably going to run my "green" engine for a long time, new engine may be just a core just in case.
Chuckd
Prevost
Stillwater mn
« Reply #3 on: August 23, 2013, 11:57:56 AM »
LOL you will need to kill the green engine it won't die on its own if you keep it cool and add oil they to seem run for ever
Scott & Heather
MCI-9 & MCI-102
« Reply #4 on: August 25, 2013, 09:47:43 AM »
Hey Cliff,
What say you about the blue engines? Reliabilt? Mine was rebuilt in 2001. Coach has a little over 600,000 miles on it. Converted to the 4 spd 740 trans. Just wanted your honest thoughts...good? bad? ugly?
Scott & Heather
Scott & Heather
MCI-9 & MCI-102
« Reply #5 on: August 27, 2013, 02:28:15 AM »
Bump for cliff. No one ever mentions reliabilt here and I really am curious on opinions :-)
Scott & Heather
« Reply #6 on: August 27, 2013, 03:56:15 AM »
They are good engines Scott but they are not a rebuilt they are a re manufactured engine by DD huge difference and carry a hefty price from DD
You have 3 stages of engine overall the in-frame,out of frame and the re manufactured and the price reflects in the different stages
The price of DD parts today is outrageous and I heard yesterday they did another price increase of 3% across the board and the shop labor increase will probably follow it always does so does the aftermarket parts price
« Last Edit: August 27, 2013, 04:25:01 AM by luvrbus » Logged
Scott & Heather
MCI-9 & MCI-102
« Reply #7 on: August 27, 2013, 10:39:33 AM »
Interesting...ok, so it's from DD. Got it. Thank you so much. Didn't realize that. So we have $$$ increases to look forward too? Great. Time to get a cummins.
Scott & Heather
« Reply #8 on: August 27, 2013, 10:43:36 AM »
LOL you haven't bought Cummins parts have you Scott
muldoonman
1991 Prevost 8V92TA
« Reply #9 on: August 27, 2013, 12:32:43 PM »
Neighbor of mine has a couple Cats left in his truck fleet and told me jokingly the other day he, after overhauling a cat,  was going back to DD's.
Ralph7
« Reply #10 on: August 27, 2013, 01:36:22 PM »
            At the Dodge dealer last week I was in informed they have done several cummins 5.9/6.7?  injectors/pump rebuilds  on newer pickups  because of contaminated fuel (fuel tanks in the bed), $6,000 and that is no joke.
          The better quality clutch for said pickups, parts only $650.  --Exhaust manifold no gaskets $500.
oldmansax
« Reply #11 on: August 27, 2013, 06:34:53 PM »
We took in a '99 1 ton that had a engine fire. Still ran but wiring harness was melted. Dodge told me there where 3  harnesses for that year. Mine would be $2200 payable in advance but that's not the bad part.
The harness is only made somewhere overseas & the plant only works 3 or 4 months a year. And they only make whichever harness they get the most calls for. I could pay the money, wait a year & still not get the harness.
I found a used one out in New Mexico. It was still $650 + shipping.
TOM
« Reply #12 on: August 28, 2013, 05:23:51 AM »
Modern diesel light truck engines are getting touchy.  To get emissions down they have to go to very high pressure fuel injection.  The pumps are very picky about fuel lubricity and water in fuel.  Some manufacturers are not doing warranty work if they feel the owner bought fuel with water in it, which I have no idea how you can tell that when you are at the pump, and for Fords anyway, the bill is usually around $16K for a new fuel system.  Not happening a lot, but enough for it to become known.  But it's more than that.  I had a 2003 Dodge pickup.  The brake flex hose to the rear axle started to rust on the fitting, and I failed an annual inspection.  Fine, it's a 16" long flex hose with a fitting on each end.  Dealer only part, no aftermarket available anywhere, and $350 at the dealer.  I was about sick to my stomach over that little bit of stupidity.
