January 18, 2018, 09:04:56 PM *
Author Topic: Changing an Eagle 10 filter NASCAR style  (Read 4927 times)
Seangie
www.herdofturtles.org
« on: August 23, 2013, 07:44:33 PM »
http://statigr.am/p/529179150022575381_46337272#/detail/529179150022575381_46337272
Lets see you do that on an MCI Wink
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
Scott & Heather
MCI-9 & MCI-102
« Reply #1 on: August 25, 2013, 08:59:27 AM »
OK...it was awesome. It was fast. Your arms were a blur...
Scott & Heather
« Reply #2 on: August 25, 2013, 09:29:38 AM »
OK - I'm impressed.  Its a minimum 1/2 hour ordeal on my LeMirage and that's if I use power tools.
« Reply #3 on: August 25, 2013, 09:35:38 AM »
LoL yea Bob he has Pharr on that Eagle trust me not all Eagles are that easy to change
« Reply #4 on: August 25, 2013, 09:51:18 AM »
If I was lucky I could remove one bolt on my Donaldson air filter assembly that quickly.  My number one problem with changing the air filter is getting it centered while putting the cover on.
Utahclaimjumper
« Reply #5 on: August 25, 2013, 10:44:40 AM »
 I would be a lot more concerned about sealing everything correctly than I would about speed, a "dusted" engine would be a high price to pay for speed.>>>Dan
« Last Edit: August 25, 2013, 03:18:40 PM by Utahclaimjumper » Logged
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
Seangie
« Reply #6 on: August 25, 2013, 08:01:22 PM »
It did take a bit of cleaning and setting everything up for the video.  Staying here at Scotts place in Southwest MI and we've been beating each other up about his MCI and my Eagle.  So just to give him a hard time about how easy it is to work on an Eagle,  I had to make the video to rub it in.  Next video will be the tire change....
'Cause you know we,
« Reply #7 on: August 25, 2013, 10:04:13 PM »
That's nice to change the filter element that fast, but didn't check to see if the filter case was dirty at all. Should clean inside just in case.
I have a horizontal Donaldson with conical filter. I made a small block of wood to hold the filter element in place to be able to screw back on the cover and 4 nuts. Good luck, TomC
Scott & Heather
MCI-9 & MCI-102
« Reply #8 on: August 26, 2013, 03:15:04 AM »
Tom, he checked everything thoroughly prior to making the video. It was propped just to make me jealous....considering my MCI is drama to change the filter. During the past month of their stay here in Michigan, we've razzed each other constantly on the MCI vs EAGLE competition. This was just a brotherly dig at us MCI guys :-)
Scott & Heather
OneLapper
« Reply #9 on: August 26, 2013, 01:30:09 PM »
Hey Sean, lets see the Tu-Flo 500 R&R video!! Bet you wish you had a GM that night, huh?
Ahahahhaa!!
OneLapper
1964 PD4106-2853
www.markdavia.com
« Reply #10 on: August 26, 2013, 01:38:42 PM »
LOL yea a 30 minute job on a GM 1 1/2 hr for a Eagle but he still has Scott beat with compressor changing on a MCI and they both have you beat on changing a starter,changing stuff on the GM at the rear is breeze  the rest sucks
« Last Edit: August 26, 2013, 01:42:30 PM by luvrbus » Logged
Oonrahnjay
« Reply #11 on: August 27, 2013, 05:31:33 AM »
     Is this a video?  Somehow the Innerweb where I live has changed it to a still pitchur!
Seangie
« Reply #12 on: August 27, 2013, 06:23:26 AM »
Ahahahhaa!!
Mark - even better than a GM - I had an amazing mechanic and friend!
Let me know when you need help with that starter!
 Bruce -  I think you have to click on the "play" button in the top right corner.
'Cause you know we,
OneLapper
« Reply #13 on: August 27, 2013, 07:12:06 AM »
Yeah, changing that starter sucks! It's even worse on my bus because the mega trailer hitch prevents anyone getting to the access hole in the bulkhead.  100% of the job need to be done from above, inside the coach, then it can lifted up and out over the tranny.
OneLapper
1964 PD4106-2853
www.markdavia.com
