May 22, 2018, 02:51:00 PM *
Author Topic: How to remove (gently) the 6v92  (Read 3024 times)
chuckd
« on: August 28, 2013, 12:53:08 PM »
Hmmm, I thought Gillig had put the engine on a set of rails, so you just roll it out.  Sure does not look like that is the correct way.  Anyone know how Gillig removed the engine from a 89 Transit?
Chucked
1979 Prevost with a spare engine, just in case.
« Reply #1 on: August 28, 2013, 01:25:52 PM »
They are easy use a pallet jack and a cradle or a dolly undo the 6 motor bolts jack the engine up either pull the bus forward or let the bus down and roll the engine out Eagles don't have rails and they are easy to remove so is the Orion transits I think those are on a Gillig chassis without rails
wg4t50
« Reply #2 on: August 28, 2013, 06:23:36 PM »
One reason I loved the MCI with the slide rails,  slide it back to do clutch & trans, just a simple one man deal.
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
« Reply #3 on: August 29, 2013, 09:29:25 AM »
If you have an automatic, you never have to worry about a clutch job (LOL).
