April 24, 2018, 11:40:36 PM *
Author Topic: Can a 24 volt Proheat coolant heater be converted to 12 volt?  (Read 2105 times)
Phil H / Chicago
« on: September 03, 2013, 03:03:28 PM »
Hey guys....I got a Proheat model XL900 24 volt coolant heater from a friend a few years back and was going to install it is an Eagle 15 that I was working on but ended up not finishing it. I was told at the time it could be easily converted to 12 volt.
Well it has sat on my shelf for the last five years waiting for me to get another bus....well I think I might have found another Eagle I am interested in and started pulling stuff off the shelf to see what I might could use. When I started talking to others about using the Proheat unit I was told that it couldn't be converted from 24 to 12 volt. So, I just decided to try to ebay it but then decided before it sells I would get another opinion.....
Can it be converted?....how hard/costly is it?
Thanks much,
Phil
Stormcloud
FMCA#407220
« Reply #1 on: September 03, 2013, 04:01:54 PM »
I was in the same situation, and ended up using a 12 volt to 24 volt converter.
http://www.samlexamerica.com/products/ProductDetail.aspx?pid=177
Runs the Webasto DBW2020 I have. Only trouble I had was blowing a fuse or 2 when the house battery bank voltage dropped too low (amperage went up).
Yes, I would do it again the same way. No, I have no interest whatsoever in this company.
Mark Morgan
1972 MCI-7 'Papabus'
8v71N MT654 Automatic
« Reply #2 on: September 03, 2013, 04:29:58 PM »
Sell it the pump,blower motor, coil, control module and wiring harness plus other items would cost a small fortune to convert to 12v
« Last Edit: September 03, 2013, 04:31:57 PM by luvrbus » Logged
« Reply #3 on: September 03, 2013, 05:47:21 PM »
It looks like that unit only pulls 3 amps at 24 volts.  A DC-DC converter should be reasonable.
scanzel
« Reply #4 on: September 04, 2013, 06:38:06 AM »
If you go to www.suremarine.com they sell the Proheat and if you look at the replacement prices for converting to 12 volt it would be better to just buy the correct one on Ebay. I had three of them all 12v sold two and am putting the new one in my coach. It is 12v wish it was 24v as my battery bank is 24v but I got a great deal on it so I will just run it of of 12v. To convert it you would need the water pump and the control module and a few other items.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
Phil H / Chicago
« Reply #5 on: September 04, 2013, 09:20:42 AM »
Thanks for the feedback guys....good to know my options.
OneLapper
« Reply #6 on: September 04, 2013, 01:29:10 PM »
I bought a unused 24vdc Webasto 2010 from a forum member here. I then bought a non-working 12vdc 2010 from another member for very little money.  I suppose I lucked out but the 12vdc unit only needed bearings, wiring repairs and a major cleaning.  I ended up swapping the 12 volt components into the new 24vdc unit. Cost to swap from 24vdc to 12vdc was $150.  It'll be less if I sell the 24 volt components.
« Last Edit: September 04, 2013, 01:37:29 PM by OneLapper » Logged
OneLapper
1964 PD4106-2853
www.markdavia.com
