April 20, 2018, 04:10:36 AM *
Author Topic: genrator question  (Read 2552 times)
uemjg
jerry
« on: September 04, 2013, 03:43:48 PM »
I was told today by Wrico that my I needed to make sure that my generator has the neutral bonded to ground.  What is the best way to do this?
« Reply #1 on: September 04, 2013, 04:11:20 PM »
The easiest way is to look for the connection between the generator chassis and the neutral wire.  If you can't see one, use a DVM set on tone to check for continuity between neutral and ground.  What kind of generator is it?
uemjg
jerry
« Reply #2 on: September 04, 2013, 04:15:41 PM »
Made by wrico.
uemjg
jerry
« Reply #3 on: September 05, 2013, 12:08:15 PM »
So as long as there is a connection between neutral of the generator head and the generator chassis then is that neutral-ground bonding?
« Reply #4 on: September 05, 2013, 01:02:29 PM »
NO.
This subject has been discussed to death in the past.  You need to use the search function and come back when you can ask a question that hasn't already been asked and answered 100 times.
uemjg
jerry
« Reply #5 on: September 05, 2013, 01:10:34 PM »
NO.
Bob,
Thanks for taking the time to respond to my question, but since I was directing this at bevans6 then anything other than a positive response is not welcomed.  what you don't know is that i have done the serch and the results have not really answered my question, so hence I am asking again.
lvbob
« Reply #6 on: September 05, 2013, 02:18:37 PM »
hoorah uemjg
1981 Eagle 10/15 series 60 740 auto
