February 18, 2018, 02:31:52 PM *
Author Topic: rts owner with parts manual-lookup  (Read 2049 times)
chessie4905
« on: September 05, 2013, 11:37:37 AM »
   Looking for part number for Vernatherm for city transit with air line connection port.
GMC h8h 649#028 (4905)
Pennsylvania-central
chessie4905
« Reply #1 on: September 08, 2013, 07:06:10 AM »
   Nobody has an RTS or parts book?
Geoff
« Reply #2 on: September 08, 2013, 10:57:30 AM »
I have the RTS 04 series parts manual and I have no idea where to look, if such a device was even used back then.
--Geoff
Geoff
'82 RTS AZ
chessie4905
« Reply #3 on: September 08, 2013, 04:41:41 PM »
   Mounted (threads) into radiator to engine coolant pipe; usually on back side of engine near fan area. It controls oil flow to torus fan. Has two oil lines (3/4 to 1 inch dia) attached to it; should have an air line connection on end of it  from a skinner valve. In my service manual, in the cooling section it it called a Fluid Fan Control Valve (vernatherm). May have also been used on the later New Looks.
Geoff
« Reply #4 on: September 08, 2013, 07:44:58 PM »
As far as I know, RTS buses never used the hydraulic fan like the Fishbowl's did.  Mine is a direct drive fan, although I have seen some RTS with a themostatically controlled air fan (i.e. Horton).
Geoff
'82 RTS AZ
chessie4905
« Reply #5 on: September 09, 2013, 05:24:25 AM »
   That makes sense, since RTS was later than 4905's. I'll repost question to New Look owners. Thanks for your input.
« Reply #6 on: September 09, 2013, 06:39:22 AM »
That valve should be in the 4106 book also I seen both types on the 4106
chessie4905
« Reply #7 on: September 09, 2013, 03:45:37 PM »
   The 4905 uses it, but doesn't use the extra air line fitting to command full fan. I figure if I can obtain the correct part number for this one, I'll have a much better chance to find one. You ask a bus parts supplier and if you don't have the part number, they look clueless.
blue_goose
« Reply #8 on: September 10, 2013, 05:44:19 AM »
Try checking with MCI, the late 1990 were built by TMC which is MCI.
Jack
