April 25, 2018, 07:19:04 AM *
Author Topic: Help with removing a 4104 wiper motor/pump  (Read 3452 times)
harleyman_1000
« on: September 06, 2013, 06:38:50 PM »
 I have a 1958 4104, and Im trying to remove the drivers side windshield motor/pump. I am in need of the instructions from the manual. Can anyone post a copy of the instructions?
Scott
St.Louis Missouri
« Reply #1 on: September 07, 2013, 08:42:42 AM »
Len Silva and Zimtok both have PDFs of the 04 manual, hopefully they will post you the link.  FWIW I pulled mine just by looking at the assembly.
p.s. have you been working on your bus without a manual 'til now?  If so you are in for a treat, it helps to have the manual , try to get the parts manual as well, helps with assemblies etc....good luck.
harleyman_1000
« Reply #2 on: September 07, 2013, 08:57:10 AM »
 I have a parts manual, but haven't looked at it yet, but will have to now.
Scott
St.Louis Missouri
« Reply #3 on: September 07, 2013, 09:28:05 AM »
When all else fails, read the instructions.
Utahclaimjumper
« Reply #4 on: September 07, 2013, 09:49:48 AM »
 So simple even an adult can do it.!>>>D
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #5 on: September 07, 2013, 10:54:55 AM »
 Roll Eyes with his bus he may need more than a 4104 manual about the only thing that is a 4104 on that one is the paper work so don't be too hard on him
harleyman_1000
« Reply #6 on: September 07, 2013, 11:20:34 AM »
It's a parts manual? I thought it would only list the parts numbers? I will look at it later today.
Scott
St.Louis Missouri
harleyman_1000
« Reply #7 on: September 07, 2013, 11:24:49 AM »
 I started taking it apart and when I tried to loosen the smaller bolt on the windshield arm, it was a, sort of shaft pin bolt, and it just came out. So now I figured rather than break it, I would try and find out the correct way to do it  Huh
Scott
St.Louis Missouri
« Reply #8 on: September 07, 2013, 11:36:36 AM »
I skimmed the parts manual....no images...The maintenance manual has a little info  re how to adjust the pantograph and an diagram  of the installed motor which may be helpful and perhaps the text discusses removal my I did not catch when I browsed.
harleyman_1000
« Reply #9 on: September 07, 2013, 12:25:47 PM »
 I think I need a build a bus for dummies book  Roll Eyes
Scott
St.Louis Missouri
« Reply #10 on: September 07, 2013, 02:28:53 PM »
Manuals here:  http://manuals.lenstudio.com/
