April 21, 2018, 01:10:26 AM *
Author Topic: Aircompresser  (Read 1944 times)
Nineforever
Nineforever
100 klms south of Yellowknife NWT Canada
« on: September 21, 2013, 09:42:42 PM »
Hello board members does any one have the model # and make of Air Compresser on a 1993 102c w/8v92ta and 1981 MC9 w/8v71n
Dave
Hyway 3 100 klms south of Yellowknife NWT Canada
Seangie
www.herdofturtles.org
« Reply #1 on: September 21, 2013, 09:50:40 PM »
Dave,
Could be a couple of models that fit.  I would assume there are a few Bendix models that would fit.  Do you have a compressor now that you are replacing?
'Cause you know we,
Driving through the night
To that old promised land'
Nineforever
Nineforever
« Reply #2 on: September 21, 2013, 09:58:59 PM »
Yes but there still in the bus and working but passing oil time to replace , able to order threw MCI but they will not give you after market part #   if i order threw MCI there approx 1100.00 less 600.00 core problem is to ship back the core to MCI from Yellowknife is at my exspence and it would be real costly .
Thanks for replys
Dave
Seangie
« Reply #3 on: September 21, 2013, 10:08:27 PM »
See if you can get the model number off the one in the Bus.  I did that and then cross referenced it through Bendix and found the replacement.  I also found later that there are better updated versions that would have fit and worked better but I kept looking for the same exact model.
My compressor had a part number stamped into the top as well as a red plate on the side of it.  Was not hard to cross reference once I got those numbers.  This is off a 1984 eagle with a silver 6v-92.   One of the more experienced mechs on the board can probably tell you what models will work in the MCI.  Give them a day or two and they will help you out.
'Cause you know we,
« Reply #4 on: September 22, 2013, 02:34:42 AM »
They are not hard to find MCI takes a a 75 degree tilt 700 or 750 cfm compressor here is a Haldex number 289915X any supplier can cross it over if Bendix is your choice same compressor will work on both engines and they are treat to replace on a MCI  Huh
« Last Edit: September 22, 2013, 02:55:08 AM by luvrbus » Logged
« Reply #5 on: September 22, 2013, 04:43:37 AM »
As said it's a Tu-flo 700 or 750 with a Detroit flange, 75 degree tilt.  OEM was Bendix, if you get a Bendix rebuilt unit the MCI price is about exactly what I paid two years ago.  You are going to have to send in the core to get a price in the $500 range.  I got mine from a local truck parts store, it was remanufactured by Bendix, which I highly recommend.
Nineforever
Nineforever
« Reply #6 on: September 22, 2013, 05:03:11 AM »
