April 25, 2018, 12:11:01 AM *
News: If you had an Online Subscription: By clicking on any ad, a hotlink takes you directly to the advertisers website.
Author Topic: 1978 MCI 5C - 35' 6V92TAw/Allison automatic  (Read 17814 times)
SkellBell
Solo looking for fulltime rig
« on: September 28, 2013, 04:19:57 PM »
http://chicago.craigslist.org/nwc/rvs/4092357640.html
Another MCI for your thoughts?
Utahclaimjumper
« Reply #1 on: September 28, 2013, 04:29:20 PM »
 Very heavy price in this market, don't believe the 10 miles per gallon, not with an automatic. I like the description that lays out all the details, even if some are suspect.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
SkellBell
« Reply #2 on: September 28, 2013, 04:43:35 PM »
Dan - what is a fair price in this market if it really does have all these bells and whistles?
« Reply #3 on: September 28, 2013, 05:08:45 PM »
Whoever did the listing seems to generally know what he/she is talking about.  That's a good thing in the sense that the buyer would have a lot of valuable information up front.  The downside could be that they may have a hard time dealing at today's market value.  If it has everything listed in good/excellent condition as mentioned, I would think in terms of 30k or even less depending on what you would think needs to be done.  Let me add though that I am by no means qualified to make an accurate estimate but am willing to guess anyway.  One problem with trying is that the pictures are not very good, so the interior could be better or worse than the impression I get.
« Reply #4 on: September 28, 2013, 05:34:57 PM »
$40,000 will get you a mid 80's Prevost by a pro converter that was never a bus with low miles that guy is dreaming he has a $20,000 unit if he is lucky in today's market
« Reply #5 on: September 28, 2013, 05:48:34 PM »
I would look at the 5C before the 9. A 5C is like a 9, only 5 feet shorter. If everything is as described, it would be a bargain even at $40 000. Unless you really want to look at a Prevost Roll Eyes... If the A/Cs are in the baggage compartments, with the plumbing and electrical, there won't be much space left for baggage. I have a 5C with the same powertrain and I get around 7 to 7.5 miles/US gal., which is normal. Great bus.
Blackie AB
muldoonman
1991 Prevost 8V92TA
« Reply #6 on: September 28, 2013, 06:00:48 PM »
Gave $57,000 for a 91 prevost xl mirage 3 years ago with 52,000 one owner miles. Heck the 15 kw Kubota gen set only had 25 hours on it.  Have spent upgrading things though. I guess if you feel a price is right for you and you have the green go for it. Enjoying it rat now parked down on the Gulf Coast in Texas.
Dave5Cs
« Reply #7 on: September 28, 2013, 06:03:50 PM »
I know a guy who looked at this one the 5C and said it was pretty dated on the inside and was not impressed. He said the guy told him he had worked on it for 20 years??? Said he was a nice guy but wanted to much and would not go below 38K for sure. Motor was in good shape, cabinets not finished.
Dave5Cs
« Last Edit: September 29, 2013, 08:15:29 AM by Dave5Cs » Logged
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
SkellBell
« Reply #8 on: September 28, 2013, 06:25:34 PM »
Dave5Cs - the pink shades would definitely have to go but did he say anything about the mechanicals? Would he be willing to talk with me?
Dave5Cs
« Reply #9 on: September 28, 2013, 06:33:40 PM »
Look him up in the members, "Geom" I am sure he would be willing to talk to you about it. His name is George.
Dave5Cs
"PATHFINDER"(Bus)
Toed 1998 Jeep TJ
SkellBell
« Reply #10 on: September 28, 2013, 07:14:36 PM »
Much thanks Dave!
tekebird
« Reply #11 on: September 28, 2013, 08:30:34 PM »
I'd steer away from anything that has been repowered with an engine the bus did not come with........too big a risk of cooling issues
« Reply #12 on: September 28, 2013, 08:55:04 PM »
The 6V92 and Allison transmision is a common upgrade in a 5. It has worked very well for numerous happy owners. Mine with 90 injectors, does not have an overheating problem.
Blackie AB
« Reply #13 on: September 28, 2013, 09:00:15 PM »
The 8v71 radiators in a 5 should handle a 6v92 without any problems they are about the same engine in cubic inches
« Reply #14 on: September 29, 2013, 03:59:17 AM »
The real expense that is not usually foreseen in buying a conversion is running gear, engine, and with MCI's the air beams, springs and other rust.  If this bus has an original 42K miles and 9K on the engine and trans, the shell is probably worth $20K at least.  Add in a usable conversion that is updateable, add $10K.  I'd give in the mid $30's for this if the story checks out.  It's probably worth a lot more than that given the miles.  It's effectively a new old bus.
Edit:  Satellite system, dual central air, Trace 4KW inverter, 350 AH of industrial Batteries, 6500W Onan, Webasto, stainless steel water tanks, put that basically new conversion stuff on a credit card and you'd spend close to $25K  Ross integral steering upgrade too, missed that the first time.  I think that for anyone who wanted a bus conversion and wanted to actually use it as opposed to have it sit in the driveway and get worked on, this bus could be ideal.  It's selling for less than I've spent on my 5C and mine has a couple of million miles on the frame.
« Last Edit: September 29, 2013, 04:26:21 AM by bevans6 » Logged
