June 18, 2018, 12:43:18 PM *
Author Topic: Priming pump.  (Read 2285 times)
Don4107
« on: October 01, 2013, 09:57:02 AM »
Would one of these work as an inline priming pump for a 8V71?
http://www.ebay.com/itm/Detroit-Diesel-Cummins-CAT-Hand-Driven-Engine-Priming-Pump-5110760-NOS-/290851135264
4107 has electric pump and works great.  Our 5B has none.  Thinking this might be a simple way to go.  I suppose there would be more chance for an air leak than with an electric pump.
Don 4107 Eastern Washington
1975 MCI 5B
1966 GM PD 4107 for sale
1968 GMC Carpenter
« Reply #1 on: October 01, 2013, 10:11:57 AM »
Bosch makes one that will just screw into the top of the filter housing they cost less than 20 bucks they work  ok
Scott & Heather
MCI-9 & MCI-102
Re:
« Reply #2 on: October 01, 2013, 10:32:17 AM »
If you had a little elf back there with fast enough arms, you wouldn't even need a gear pump Smiley
Sent from my iPhone using Tapatalk. Clumsy fingers may contribute to mistakes.
Scott & Heather
Geoff
« Reply #3 on: October 01, 2013, 01:27:44 PM »
That is the standard Detroit Diesel priming pump-- I have a couple of them.  What is nice about these is you can hook the pump to the secondary filter, and by having a manual oil pressure gauge on the pump you can pinch off the return line and make sure you have no leaks (esp. the jumper fuel lines) at 60 psi.  Let it sit for 5 minutes at 60psi and you know you are good to go.  You can't get that kind of pressure off an electric fuel pump.
Geoff
'82 RTS AZ
« Reply #4 on: October 01, 2013, 03:47:41 PM »
Clifford, Is this the one you mean.  If so, it seems it would have a very short stroke and would take quite a bit of pumping.
http://www.amazon.com/Bosch-2447010038-Hand-Primer-Pump/dp/B001CO92F2
« Reply #5 on: October 01, 2013, 04:00:21 PM »
They are not all that slow Lin a priming just creates a suction I cannot tell the difference between the Bosch and the Detroit,Cat Mack or Cummins primer pumps in strokes or time, I have both but use the electric pump you can call me lazy  Lips Sealed
« Last Edit: October 01, 2013, 04:02:57 PM by luvrbus » Logged
