February 24, 2018, 06:05:33 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: 50 amp versus 30 amp  (Read 6290 times)
« Reply #30 on: November 05, 2013, 08:54:36 AM »
There are better 15 amp to 30 amp converters than the little ones that plug in.  I had one that has a short length of cord, but I lost it somewhere.  Many inverters have a setting for the numbers of amps they are hooked up to.  I set mine down from 30 amps when I plug into a smaller circuit.
scanzel
« Reply #31 on: November 05, 2013, 10:29:43 AM »
50 amp is my way to go. I have 8 100 ah agm batteries connected to my Magnum 4024 wired for 220 back to a Square D QO 50 amp panel located in my bedroom area. I have the Magnum remote panel and the battery sensor also. All this is wired through a Kraus Naimer 100amp rotary switch set up for OFF/Inverter/Shore/Generator. This way I can feed my ac panel with what ever ac I need at the time. My lighting and other accessories will be or are going to be 12v & 24v dc. I am looking to have all led lighting. The only heavy ac loads should be 2 Penguin 13500 btu with heat pumps and the home style   18 cu refrigerator, stove is propane but has an over stove microwave vented to the roof. Some day I would also like to have some solar pwr too. Coming in for shore power I have the Progressive Industries 50 amp monitoring unit with surge supression with the remote panel which shows your incoming voltage and amps when there is a load. Great little monitor because when on shore power it shows your amp load on each leg of 220.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
« Reply #32 on: November 05, 2013, 11:43:41 AM »
 50amp hook up is actually two legs of 50 giving you an available 100 amps combined, I learned early on that 30 amp just ain't enough to stay cool with here in the desert.  Wink Just a side note, when the temps drop below 96 here it gets down right nipply Grin Bring on the summer! Smiley
« Last Edit: November 05, 2013, 11:51:57 AM by Van » Logged
« Reply #33 on: November 05, 2013, 02:34:15 PM »
I have my non inverter items separated in another breaker box from the inverter powered items. Hence, If I'm on limited power pole, I can just turn off the 30amp supply to the inverter breaker box and run off a combination of inverter and power pole. I would use this, for instance, if I'm at a friends house with only 20amps coming to the bus and running one roof air. Then if I wanted to say run the microwave, or make coffee, or toast, I can run it off the inverter and worry about recharging the batteries later that night when the A/C is no longer needed. Good Luck, TomC
Pages: 1 2 [3]  All   Go Up
